Cam chain tensioner adjustment KZ1100
- 76KZ900
17 Oct 2015 11:09
This tensioner is a bit different than the 900/1000 ones I've seen. What is procedure for setting cam chain tension ?
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
76KZ900 (sold) regret
03ZRX1200R (sold) regret
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
- 76KZ900
Re: Cam chain tensioner adjustment KZ1100
27 Oct 2015 04:08
Anyone ?
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
- jackleberry
27 Oct 2015 07:21 - 27 Oct 2015 07:21
Could you describe how it's different? Pictures?
As I understand it, the KZ1100 should have the same kind of automatic adjuster the KZ1000 does.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
Last edit: 27 Oct 2015 07:21 by jackleberry.
- missionkz
27 Oct 2015 07:58
Isn't that addressed clearly in your service manual? I think it's pretty clear in the owners manual too.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- Puffin
27 Oct 2015 10:34
76kz900 maybe you have an aftermarket manual adjuster fitted ! A photo would help clear things up
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
- RonKZ650
27 Oct 2015 18:16
Completely automatic and worked fine. Of course some owners think the factory is always wrong, so fitting an aftermarket unit is a possibility, then adustment is anyones guess, as the aftermarkets sell things, and then don't care 25 seconds later by supplying any guidance.
27 Oct 2015 18:58
And setting it wrong can ruin the motor. Pics!
- 76KZ900
27 Oct 2015 22:28 - 27 Oct 2015 22:34Attachment Screenshot_2015-10-28-03-39-15.png not found
I'm including a pic. But really just looking for someone that has done this on a 1100. My previous kz were I believe put timing mark to TDC and loosen lock nut and bolt, then tighten.
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
Last edit: 27 Oct 2015 22:34 by 76KZ900.
- OnkelB
28 Oct 2015 00:00 - 28 Oct 2015 00:05
That is a fully automatic cross wedge style tensioner, once installed there's no adjustment needed.
Remove the plunger cap (17 mm nut on the side of the tensioner) and pull out the wedge and spring.
With the valve cover on, rotate the engine by the crank to tighten the cam chain at the front and put all chain slack at the rear.
Install the tensioner, then install the wedge and spring and put the cap back on. Note that you must have the valve cover on before installing the wedge, spring and cap.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 28 Oct 2015 00:05 by OnkelB.
- 76KZ900
28 Oct 2015 00:10
Thanks that's what I needed
78KZ400 (sold)
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
78KZ1000 (sold)
82KZ1100 (sold)
83KZ1100 LTD Shaft
28 Oct 2015 07:05
If it stops adjusting, the guides might be worn out or it is defective. Be careful.
- Puffin
30 Oct 2015 00:51
Yes thats the factory one . Strip it clean it reassemble as per manual and your good to go
KZ1100
KZ1100
