Oil Cooler Question
22 Sep 2015 09:40 #691361 by Tokyo_OG
Noob Question - What is this? was created by Tokyo_OG
Can anyone tell me what this is?
Attachment IMG_2469.jpg not found
22 Sep 2015 09:45 - 22 Sep 2015 09:49 #691362 by 650ed
Replied by 650ed on topic Noob Question - What is this?
Oil cooler by Lockhart. Ed
Attachment 00003a-110.jpg not found
Last edit: 22 Sep 2015 09:49 by 650ed.
22 Sep 2015 09:45 #691363 by davido
Replied by davido on topic Noob Question - What is this?
Theres a lot of stuff there. Which bit do you need identified?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Tyrell Corp
22 Sep 2015 09:54 #691365 by Tyrell Corp
Replied by Tyrell Corp on topic Noob Question - What is this?
It is a period bolt on oil cooler. 'period' bits like this are quite sought after.
22 Sep 2015 09:55 #691367 by Tokyo_OG
Replied by Tokyo_OG on topic Noob Question - What is this?
Ed got it for me.
22 Sep 2015 09:56 #691369 by Tokyo_OG
Tyrell Corp wrote: It is a period bolt on oil cooler. 'period' bits like this are quite sought after.
would it therefore be a crime to remove it? I'm wondering if i need it and if i could replace it with something else. I'm trying to restore the bike it's in pretty rough shape.
22 Sep 2015 09:58 #691371 by Grnole
Replied by Grnole on topic Noob Question - What is this?
I am sure i am one of many responses here.
But oil coolers dependent on your location are not necessary. If you had a bit more info of where you are... how you plan to ride, what you plan to do... there is likely not a need for it at all... dependent on those answers....
Mike
1980 KZ1000 LTD -B4
1984 Yamaha FJ1100
1972 Honda CL350 (sold)
22 Sep 2015 10:14 #691374 by 650ed
You don't need one at all unless you plan to race the bike or ride in extreme heat. Unless you are towing a heavy load behind the bike (very unlikely) if the temperatures in Utah when you ride are typically below 97 - 100 degrees I would simply remove it. The only other exception would be if the bike came with one as original standard equipment (such as GPz 1100). I didn't see what model bike you have, but I doubt it came with an oil cooler otherwise it probably would not have a Lockhart cooler. Ed
22 Sep 2015 10:15 #691375 by Tokyo_OG
Grnole wrote: I am sure i am one of many responses here.
Mike
I plan to drive it daily up in the hills. I live in Utah so a higher altitude is a thing. I think it looks ugly personally. Would i need to replace it?
22 Sep 2015 10:16 #691376 by Tokyo_OG
I've got a '78 z650 C
22 Sep 2015 10:23 - 22 Sep 2015 10:25 #691380 by pete greek1
Replied by pete greek1 on topic Noob Question - What is this?
If you do remove it you will have to replace the fittings where the hoses connect to the back of the motor with the stock fittings, so don't remove it until you get those fittings
Pete
Last edit: 22 Sep 2015 10:25 by pete greek1.
The following user(s) said Thank You: Tokyo_OG
22 Sep 2015 10:33 - 22 Sep 2015 10:36 #691385 by 650ed
Tokyo_OG wrote: I've got a '78 z650 C
That model definitely was not equipped with an oil cooler as stock equipment. You don't need it. I have about 60,000 miles on my KZ650-C without one, and it can get pretty hot here in the summer. I've had the bike 38 years and have often ridden it when the temperature is above 95 degrees; no problems. Ed
Last edit: 22 Sep 2015 10:36 by 650ed.
