Oil Cooler Question
- Tokyo_OG
Noob Question - What is this?
22 Sep 2015 09:40
Can anyone tell me what this is?
Attachment IMG_2469.jpg not found
Re: Noob Question - What is this?
22 Sep 2015 09:45 - 22 Sep 2015 09:49
Oil cooler by Lockhart. Ed
Attachment 00003a-110.jpg not found
Last edit: 22 Sep 2015 09:49 by 650ed.
- davido
22 Sep 2015 09:45
Theres a lot of stuff there. Which bit do you need identified?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Tyrell Corp
22 Sep 2015 09:54
It is a period bolt on oil cooler. 'period' bits like this are quite sought after.
- Tokyo_OG
- Tokyo_OG
22 Sep 2015 09:56Tyrell Corp wrote: It is a period bolt on oil cooler. 'period' bits like this are quite sought after.
would it therefore be a crime to remove it? I'm wondering if i need it and if i could replace it with something else. I'm trying to restore the bike it's in pretty rough shape.
- Grnole
22 Sep 2015 09:58
I am sure i am one of many responses here.
But oil coolers dependent on your location are not necessary. If you had a bit more info of where you are... how you plan to ride, what you plan to do... there is likely not a need for it at all... dependent on those answers....
Mike
Mike
1980 KZ1000 LTD -B4
1984 Yamaha FJ1100
1972 Honda CL350 (sold)
1984 Yamaha FJ1100
22 Sep 2015 10:14Tokyo_OG wrote:Tyrell Corp wrote: It is a period bolt on oil cooler. 'period' bits like this are quite sought after.
You don't need one at all unless you plan to race the bike or ride in extreme heat. Unless you are towing a heavy load behind the bike (very unlikely) if the temperatures in Utah when you ride are typically below 97 - 100 degrees I would simply remove it. The only other exception would be if the bike came with one as original standard equipment (such as GPz 1100). I didn't see what model bike you have, but I doubt it came with an oil cooler otherwise it probably would not have a Lockhart cooler. Ed
- Tokyo_OG
22 Sep 2015 10:15Grnole wrote: I am sure i am one of many responses here.
Mike
I plan to drive it daily up in the hills. I live in Utah so a higher altitude is a thing. I think it looks ugly personally. Would i need to replace it?
- Tokyo_OG
- pete greek1
22 Sep 2015 10:23 - 22 Sep 2015 10:25
If you do remove it you will have to replace the fittings where the hoses connect to the back of the motor with the stock fittings, so don't remove it until you get those fittings
Pete
Pete
Last edit: 22 Sep 2015 10:25 by pete greek1.
The following user(s) said Thank You: Tokyo_OG
22 Sep 2015 10:33 - 22 Sep 2015 10:36Tokyo_OG wrote: I've got a '78 z650 C
That model definitely was not equipped with an oil cooler as stock equipment. You don't need it. I have about 60,000 miles on my KZ650-C without one, and it can get pretty hot here in the summer. I've had the bike 38 years and have often ridden it when the temperature is above 95 degrees; no problems. Ed
Last edit: 22 Sep 2015 10:36 by 650ed.
