Kz750E exhaust on 750h
- dom2570
03 Sep 2015 07:22
I know it might seem like a stupid question, but I want to double check before I buy anything. I found a delkevic 4-1 I would really like to pick up, but it says it is for a 750E, my first thought was that it wouldn't matter because the engines are pretty much the same, but I wanted to double check with the experts here first. Thanks in advance.
Whip it like a mule!
Re: Kz750E exhaust on 750h
03 Sep 2015 08:26 - 03 Sep 2015 08:36
Probably yes. That delkevic exhaust should fit any KZ650 or 750-4. You'll probably have to fab a muffler bracket.
Someone here on KZR installed one of the systems, but I don't recall what size bike.
I put a stock 750E exhaust system on my 650-CSR which has the same frame as the 750H Ltd.
1981 KZ650-CSR w KZ550-ltd wheels & KZ750-E1 mufflers.
Last edit: 03 Sep 2015 08:36 by martin_csr.
03 Sep 2015 08:43
It should fit. The rear bracket might need a extension if the stay is in the wrong place.
- dom2570
Re: Re:Kz750E exhaust on 750h
03 Sep 2015 09:26
I figured they were pretty much the same frame and engine.
03 Sep 2015 11:44 - 03 Sep 2015 22:47
The 750E mufflers fit pretty good. I had to use the E muffler brackets --- the 650-CSR brackets are shorter (the 750H are the same as the 650).
Last edit: 03 Sep 2015 22:47 by martin_csr.
