do these plugs look ok?
  • kayodash
  • kayodash's Avatar Topic Author
01 Sep 2015 16:58 - 01 Sep 2015 17:00
#688226
Hello, so after some carburetor work on my 84 kz550. I'm double checking my work. And am wondering if I'm a little lean. Bike runs pretty decent and I don't think I hear the carbs popping on deceleration. Starts with choke and has to warm up and play with idle a little to be able to take choke off. After warming up it can idle at 1000rpm to 1300rpm no problem. Acceleration seems pretty smooth. Doesn't seem to jerk at all like its out of gas. Doesn't seem to miss while I'm cruising either. Only reason I think it may be lean is because of the plugs, they are new with less than 100 miles. I attached some pictures. They don't look glazed like I've seen online but Someone please let me know what their opinion on the plugs are.
1984 Kawasaki KZ550 LTD F2
1981 Kawasaki KZ750 LTD
Last edit: 01 Sep 2015 17:00 by kayodash.
  • missionkz
  • missionkz's Avatar
Re: do these plugs look ok?
01 Sep 2015 17:15
#688228
Look pretty good to me but your main jetting is harder to read compared to 1/8 to less the half throttle which is probably +90% of your riding.
You need to ride it WOT and do a chop, pull off the side of the road and look again.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • kayodash
01 Sep 2015 17:27
#688229
What do you mean "do a chop"?
  • JDRAKE4200
  • JDRAKE4200's Avatar
01 Sep 2015 17:52
#688233
Turn the bike off at full throttle. This will give you the reading.
Keep the shiny side up!!!!
1976 KZ900 LTD
2004 Sportster 1200 Custom
1981 KZ550 LTD
1994 GSXR 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Sep 2015 19:12
#688239
I'd go to NGK plugs. They are made for the bike. The heat ranges vary between makes.
  • kayodash
01 Sep 2015 21:53
#688268
K ill get some NGKs , and as for killing it at WOT can this be done in my driveway after the bike is warm? Or does it need the load on the engine?
  • Irish Yobbo
  • Irish Yobbo's Avatar
01 Sep 2015 22:04
#688270
kayodash wrote: K ill get some NGKs , and as for killing it at WOT can this be done in my driveway after the bike is warm? Or does it need the load on the engine?
Well, if you have a particularly long driveway or a particularly slow bike...
WOT - Wide Open Throttle. Best to bring it out to an open road, put it in a higher gear and open the throttle. Use a little rear brake if you want to stop yourself from accelerating too fast or at all - then switch the bike off and pull over. That way, the spark plug is igniting the air/fuel mixture at WOT when switched off.
1981 KZ750 LTD
02 Sep 2015 05:29
#688281
Don't even THINK about running that engine at WOT without a load. Doing that with the bike in neutral or with the clutch pulled in will damage the engine. Ed
  • kayodash
02 Sep 2015 09:31
#688315
Took her out this morning, hit the country road by my house. Went WOT
And man does that bike move. But killed it with the switch pulled over. Popped the plugs out and they looked pretty similar to the pictures I posted. Maybe just a slight smidgen lighter color, but it could've been the difference between the lighting. It was late afternoon yesterday and morning today. There's no delay in power. I noticed If I crack the throttle while idle it may or may not die. I'm guessing because I still haven't synced the carbs to the bike yet. But as for drivability and cruising I haven't noticed any real issues.
  • missionkz
02 Sep 2015 10:48
#688323
OK, for more power it looks like you could move up another one or two main jet #'s.
Most daily street riders are not really driving strong into the main jet, with the slide and needle pulled etc....
Bruce
1977 KZ1000A1
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Sep 2015 11:21
#688327
With the correct plugs you'll get better readings.
