stripped oil filter cover bolt hole
  • JimB
  • JimB's Avatar Topic Author
28 Aug 2015 15:34
#687516
Hello KZR's. I was doing routine maintenance today n my 1978 KZ 1000 and When I was putting the oil filer cover bolt back in I stripped the hole. :blink:
Does anyone know what size hole this is so I can get a tap to ream out the hole again? Or if anyone has any other ideas they would be appreciated.
Thanks for your help.
JIm
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
  • MFolks
  • MFolks's Avatar
Re: stripped oil filter cover bolt hole
28 Aug 2015 15:40
#687517
Contact www.z1enterprises.com as they probably know the size, and how to repair it.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Aug 2015 16:38
#687528
Did you try to run the bolt in without the cover,filter and spring?
  • JimB
28 Aug 2015 17:25
#687533
@ Mfolks,...yes. I will contact Z1 if no one on this forum has experienced this problem. Even though it was very stupid of me I am thinking someone else has done this.
@ Zwest,...yes I tried to run it thru and got a bolt from another motor and tried it. The bolt is going in crooked.
Any help would be appreciated
The outside threads measure 19.54 mm so I am thinking this is a 19mm bolt. so 19 x 1 tap is what i need.
JIm
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Aug 2015 18:02
#687539
If you have a extra bolt you might try making a thread chaser out of it. I did that with a spark plug that wouldn't go in. I ground two slices in it and ran it in back and forth little by little until snug. Normally only the first few threads get munged up.
  • JimB
28 Aug 2015 19:20
#687550
@swest, ,,that was a good idea. Since the new bolt did not work I went back to the old bolt and made a thread chaser as you recommended. But I did it a little differently. I got a file and filed down the first couple of rows of threads and then when I put the bolt back in,...it was in the hole enough that it did not allow it to cock sideways and stayed straight in as it caught good threads.
What a dumb mistake for a couple of reasons. I did not take the pipe off and when the drain bolt came around it cocked the bolt as it went in. And second since I did not want to lay on the ground I reached under there and went right to the socket instead of starting the threads by hand. .
Well,...got lucky. Crisis avoided for today. The bike will be ready to ride this weekend with new Shell Rotella.
Thanks for the inputs.
Jim
