Just not running hard enough
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Just not running hard enough
27 Aug 2015 05:32
#687296
Tune up. Do you have a manual?
  • drewd2385
  • drewd2385's Avatar Topic Author
27 Aug 2015 09:04
#687311
swest wrote: Tune up. Do you have a manual?
Yes I have the manual what should I check?
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Aug 2015 09:18
#687314
Clear tube test/ float level.
  • Tyrell Corp
  • Tyrell Corp's Avatar
27 Aug 2015 09:52
#687326
#1&2 cylinder black with oil 3 and 4 are tan and dry
Is it smoking or using oil? are you sure it is oil not soot (rich mixture) ? Did you get around to checking the compression?
When you fire it up, does 1 and 2 take a lot longer to warm up - check the header temperatures carefully.
Your problem could even be on 3 and 4, not running right, and the half choke rich mix sooting 1 and 2...
  • drewd2385
27 Aug 2015 10:43
#687335
swest wrote: Clear tube test/ float level.
How do you clear tube test?
  • missionkz
  • missionkz's Avatar
27 Aug 2015 10:48
#687338
Use the search feature and you'll find countless threads on this technique.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
The following user(s) said Thank You: drewd2385
  • drewd2385
27 Aug 2015 10:48
#687339
Tyrell Corp wrote: #1&2 cylinder black with oil 3 and 4 are tan and dry
When she fires up she runs fine with choke on then let her warm up turn choke half way off and she will idle I turn it all the way off and she spits and sputters and dies. And it does look like she's spitting a little oil out the exhaust but that just started happening I don't have a temp gun so I don't know how hot they are getting I will try and get a compression test tonight after I get off
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Aug 2015 11:06
#687344
Valve adjustment?
  • baldy110
  • baldy110's Avatar
27 Aug 2015 12:30
#687351
I would say based the choke issue you still have a dirty / clogged carbs.
  • spdygon
  • spdygon's Avatar
27 Aug 2015 12:53
#687356
first check for spark on all four plugs...if ok then your carbs need a good cleaning.
I would not run pumpers for drag racing...not needed.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • drewd2385
27 Aug 2015 14:37
#687363
swest wrote: Valve adjustment?
Haven't got that far into it Steve but will thanks I'll post again after I mess with a few things tonight
  • drewd2385
27 Aug 2015 14:39
#687364
spdygon wrote: first check for spark on all four plugs...if ok then your carbs need a good cleaning.
Yes I'm getting spark on all plugs and I can't afford flatslides yet lol so I'm running these for the rest of year and I'll buy flat slides over winter
