compression test on an '82 kz1000
  • JoyceD
  • JoyceD's Avatar Topic Author
23 Aug 2015 17:47
#686898
We have an '82 KZ1000 that my husband wants needs to do a compression test on. However, we don't know what psi it should test to. We're ordering a book on it, but he'd like to know today, if anyone knows, because he may need to order parts tomorrow so they will be in when we get back home. (We both drive truck over the road.)
<3
Re: compression test on an '82 kz1000
23 Aug 2015 18:47
#686904
Here's what the KZ1000 Kawasaki Service Manual shows. Be SURE to follow the instructions carefully, otherwise the compression readings will not be accurate. Ed
Attachment 00003c-12.jpg not found
  • Nessism
  • Nessism's Avatar
  • Away
23 Aug 2015 21:36
#686933
Better check the valve clearance before performing a compression check. If the clearance is gone and the valves are being held open your compression will be low.
Oh and if the bike has sat for a long time the compression will often be low because the rings get sticky. Perform a good old Italian Tune up and check the compression in a few hundred miles.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Aug 2015 21:52
#686938
Spot on. B)
  • JoyceD
25 Aug 2015 04:22
#687060
Wow! Thanks! 188psi, and two of the cylinders were at 92 &95 psi, and another was at 65! No wonder the Harley passes it lately! Robert says that is our winter project this year. I get to learn how to rebuild my KZ! Woohoo!
On the down side, my riding is over for the season. :-/
<3
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Aug 2015 06:05
#687068
Do your valve adjustments and they may come back up. The weathers is turning already there? Pics?
  • JoyceD
25 Aug 2015 11:07
#687099
It's been cool the last couple of days. We both go back out in the trucks today, so we won't get much more riding in. I have to be back in two weeks, but Rob might stay out longer. North Dakota gets cold earlier than a lot of places. We're talking about looking for a snowmobile for winter riding up here.
<3
  • missionkz
  • missionkz's Avatar
25 Aug 2015 11:20 - 25 Aug 2015 11:20
#687100
I think it will end abruptly here too.... we've already had many nights in the mid-high 40's!!!
Those 30-45 degree temp swings in 24 hours are a bad sign for us in the Rockies....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 25 Aug 2015 11:20 by missionkz.
  • JoyceD
25 Aug 2015 11:48
#687102
Yeah, those temp swings are definitely summer winding down.
I'm glad Robert decided to make this our winter project instead of doing it himself next time we get home. I want to learn how to do this. :-)
<3
