Dynamo rotor removal
- Drafter89
22 Aug 2015 18:00
Anybody know of a way to get the dynamo rotor off without the special tool/ puller ? I'm working with a 76 kz400 d model
78 KZ 400 C1-Daily Driver
New Albany,IN
New Albany,IN
Re: Dynamo rotor removal
22 Aug 2015 20:51
I don't know about the 400 but the steering head bolt fits and with a ball bearing it will drive it off. I have a old one I use now.
- Tyrell Corp
23 Aug 2015 03:49
For the bigger fours I used a CB750 rear wheel spindle before I got the tool, it is just a metric bolt thread if you can find one of the right size.
- Drafter89
26 Aug 2015 04:45
Now do I really need to take this thing off to split the cases?
New Albany,IN
New Albany,IN
- Tyrell Corp
26 Aug 2015 05:38
Alternator rotor is removed to replace crank oil seal. Get a manual.
- Drafter89
26 Aug 2015 05:42 - 26 Aug 2015 05:43
I have a manual and It told me to use the tool I was just seeing If I really need the tool and If it was actually necessary to remove this to split the cases. I mean the manual sais it has to be removed so I guess Ill get the tool because my inexperienced self wont be able to figure out any other way to take this off lol
New Albany,IN
New Albany,IN
Last edit: 26 Aug 2015 05:43 by Drafter89.
26 Aug 2015 06:07
Why are you splitting the cases?
- Drafter89
26 Aug 2015 06:16swest wrote: Why are you splitting the cases?
i started a thread the other day about this motor and the pistons being seized to the bores...finally got those unstuck and the cyclinder off but the motor is still locked up. This was a junk bike I bought for almost nothing so I figured I could tear the motor down in hopes to learn how it all works.
New Albany,IN
New Albany,IN
- Drafter89
26 Aug 2015 06:22
Buut I forgot to search this site on this topic until just now and I found some useful info. So in the future Ill so some searching first before I start a pointless thread. Sorry
New Albany,IN
New Albany,IN
- Tyrell Corp
26 Aug 2015 06:47
Good luck, just if the motor is badly stuffed just use it as a learning exercise, the cost of parts, boring, skimming and gaskets, oil seals etc soon makes a 'free' engine a lot more expensive then finding a decent running motor. You may need to remove the clutch centre nut, this is done mega tight and needs an air impact wrench...or a grinder if the motor is scrap
