Engine not turning over. Troubleshooting help.
- LineArtist
Re: Engine not turning over. Troubleshooting help.
27 Aug 2015 08:57
It's hard to follow: can you list all the things you have done and looked at from the beginning? And what changes have you noticed on the bike?
1
2
3
4
5
1
2
3
4
5
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
'06 HD 883R
- Tokyo_OG
27 Aug 2015 09:18
1. Cleaned the bike.
2. Cut, stripped and reconnected questionable/ damaged connections around the bike. (Ignition Module, Grounds,)
3. Fully charged the battery
4. Checked spark using a spark tester. Checked again with the spark plugs.
No difference from the video I posted originally. My spark may not be strong enough. I haven't checked my ignition coils yet.
- flextx500
27 Aug 2015 09:26
Ok, so there is some spark. I haven't seen any mention of fuel yet. Have the carbs been thoroughly cleaned? Are the spark plugs wet with fuel?
- Tokyo_OG
27 Aug 2015 09:34
In all honesty I haven't checked yet. That was going to be my next order of business, I was under the impression that it would start regardless it just may not run smoothly.
- flextx500
27 Aug 2015 09:44
I just picked up an 83 750 that hadn't been run in 5 years. Every jet in all 4 carburetors was plugged.
It would fire up for a few seconds if I sprayed a little carb cleaner in the air box. You can try that, but don't try to run it on carb cleaner for more than a few seconds, it cleans the oil off of the cylinder walls and then you'll have more problems.
The following user(s) said Thank You: Tokyo_OG
- Tokyo_OG
27 Aug 2015 09:48
I'll try cleaning the carbs out. Once I get the bike started I plan to do some serious maintenance that's been neglected for the past two years.
