Unsticking a stuck motor
- ed spangler
- Tennessee Z
Re: Unsticking a stuck motor
20 Aug 2015 04:37Nessism wrote: Sounds like you have already done what you could. Time to pull the engine apart.
^^^^^^^^^+1
Yep,Nessism said it best.
Sorry!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
- Drafter89
20 Aug 2015 07:34 - 20 Aug 2015 07:34swest wrote: At this point the idea is to get the pistons out and assess the damage. If you can get the block to separate and wedge it up just slightly, you may be able to drive the piston out a little at a time.
I used your method with the block of wood.... pistons are out, the one that was a pain looks like it was melted to the bore..weird. but now I have bigger problems.
78 KZ 400 C1-Daily Driver
New Albany,IN
New Albany,IN
Last edit: 20 Aug 2015 07:34 by Drafter89.
- Drafter89
20 Aug 2015 07:37
When I was taking the head off I noticed one of the bolts for the cam sprocket was missing. Im thinking it fell down in the motor because its locked up still, its like its trying to move but something is wedged in a gear or something.
Time to tear the motor down
Should be a good learning experience though
New Albany,IN
New Albany,IN
- Drafter89
20 Aug 2015 07:39Irish Yobbo wrote: My old daewoo once blew a headgasket and so much coolant got into the oil that it seized the engine. I towed it up a hill, put it in fifth and got up to speed to roll start it - it took a couple of tries before the engine started turning over again. I then changed the oil and put some chemi-weld in the coolant, and I drove it daily for another year
If the engine is seized you can get it running again - but if you care about the engine, you really need to strip it down. If you can get it running you're just delaying the inevitable - you will need to strip it down later.
Yep, thats going to be my weekend project
New Albany,IN
New Albany,IN
20 Aug 2015 08:14
ANOTHER reason PO's suck.
