Cleaning up the motor
- Knightmares
15 Aug 2015 16:44
I am working outside and the motor is in pieces do to a piece of %^$@# that took my money and did not finish the work he was paid for. Any way I have ordered parts and have to have the jugs honed and I am low on money. I plan on buying a Rubbermaid container to store the motor until I can work on it. The old motor oil has not been properly drained and I want to remove the dirt, and debris. I have read purple power works well, and kerosene. Looking for suggests from the community.
- peter1958
Re: Cleaning up the motor
15 Aug 2015 16:54
ACTUALY diesel works very well without staining the cases.
www.kzzone.com/
The following user(s) said Thank You: Knightmares
- Knightmares
15 Aug 2015 17:07
I will try it. I do not have any diesel equipment so off to buy a little jug and the rubber maid.
Thank you
Thank you
- MDZ1rider
18 Aug 2015 10:46
Purple power works great. I use it in my parts washer. I don't know if you have Advanced Auto in your part of the world, but they sell a 5 gallon container of PP that's a real bargain. 1 gallon containers are $12-13.00 most places. Advanced Auto sells the 5 gallon container for about $25.00. They don't normally display the 5 gallon container on the floor. You have to ask at the counter.
- davido
18 Aug 2015 11:41
I took mine up to the local garage and blasted it with the high pressure power washer. Gets in all the nooks and crannies .Clean as a whistle after that.You will need to block up any holes though and wear your wellies.
For degreasing,I use brake cleaner.
Good luck
Good luck
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- jackleberry
18 Aug 2015 13:38
Another tip... WD-40 works better than any degreaser at dissolving grease and grime. You can then follow up with simple green/purple power/whatever to get rid of the WD-40. Or just leave it, it'll prevent things from rusting while they sit.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
18 Aug 2015 15:57
He stole my diesel trick.
:lol: Cheap too. :whistle:
- Techie123
25 Sep 2015 17:02
Greetings,
Whenever cleaning aluminum DO NOT EVER use Purple Power. Yes it works wonders, BUT it will remove the surface protection all aluminum has. Any aluminum part exposed thereafter to oxygen will oxidize, thus turning a milky color and then to aluminum oxide. That surfaced will be ruined for most ever. Use diesel, WD40, mineral spirits, gasoline if you really have to, soap and water (be very careful of which soap), or you can use Desolv-it or ZEP. Please do not use Purple Power on Aluminum ever...
25 Sep 2015 17:12 - 25 Sep 2015 17:13
and NEVER use over cleaner. I t will permanently ruin the aluminum. Link below shows what happens. Ed
www.hdforums.com/forum/detailing/229259-...worst-nightmare.html
Last edit: 25 Sep 2015 17:13 by 650ed.
- eddiem
- KZR FLAG RELAY CARRIER #63
25 Sep 2015 17:46
I got some of this and just used it the other day. It did a pretty good job.
Simple Green 13406 Extreme Aircraft and Precision Cleaner
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
- Old Man Rock
27 Sep 2015 08:54 - 27 Sep 2015 08:58
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 27 Sep 2015 08:58 by Old Man Rock.
