Taking motor of 82 550 out
- milehighkz550
12 Aug 2015 17:56
Do i have to take the top half of the motor off before i can take the bottom out , or is there a way to remove the motor as a whole ?
- chirpy999
Re: Taking motor of 82 550 out
13 Aug 2015 04:01
Hi , you should be able to remove the engine complete. I did on a 81
Thanksi
Thanksi
13 Aug 2015 05:59 - 13 Aug 2015 06:05
Last edit: 13 Aug 2015 06:05 by SWest.
- loudhvx
13 Aug 2015 07:24
Yes, it can come out as one piece, but you will want to remove the sprocket cover to make it easier. And yes, you should read the many manuals available for the 550's. There are several in my signature.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
13 Aug 2015 07:46
Yes, Loud has made it very easy to keep out of trouble on these models.
- kz n az
13 Aug 2015 10:19
I did on my 750. Not ez for an old guy when its 105 in the garage (Phx AZ )
- milehighkz550
13 Aug 2015 11:18
thanks much to all of you . I will be looking at the manual and getting things done right !
- harm
- Tom
13 Aug 2015 12:09
another person to help would be a good idea cuz the engine is pretty heavy and you dont want hurt yourself because then you cant go riding!
Why are you taking it out?
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- milehighkz550
14 Aug 2015 12:59
because i got it off CL and i mentally just need to see whats going on, on the inside for my own good . Get a game plan from here and the motor also has a lot of grease and grime so im going to clean the engine really well while its out .
14 Aug 2015 13:27
I don't quite understand. Have you run the bike yet? Aside from being dirty, does it seem to have any problems when you run it? Taking an engine apart out of curiosity just to see what's going on inside seems like an expensive (you'll need new gaskets, etc.) and risky (unless you have experience, proper tools, manual, etc.) proposition. Generally what goes on inside is there are pistons that go up and down, valves that open and close, etc. :laugh: All kidding aside, these engines are very durable and ripping one apart can be expensive, so if it doesn't need to be done it can be a waste of time and money.
If you have run it and there seems to be some problems I would recommend doing some diagnostics before taking the engine out or taking it apart. At the very least a compression test and leak down test should be done first since neither can be performed after you've pulled the engine apart. Those tests should give you some indication of the condition of the engine and let you know if the valves are leaking, rings are leaking, etc. Also, if you plan to replace the engine sprocket, remove the clutch basket, etc. removing the related fasteners is easier with the engine in the frame than with it out of the frame. In fact, unless you have an engine stand handy the same is true of removing the cylinder head, cylinders, and most other parts. Ed
- milehighkz550
31 Aug 2015 10:25 - 31 Aug 2015 10:25
moderator please move . This bike is now a parts bike . I am selling indivual parts or bike as a whole . Things have happened in life where i can no longer ride . Please move to for sale and if anyone has questions please PM me
Last edit: 31 Aug 2015 10:25 by milehighkz550.
