KZ750/4 & KZ650 Crankshaft Seal
11 Aug 2015 19:48 - 11 Aug 2015 19:49
Looks like crankshaft oil seal PN 92050-080 is discontinued. Searched and found some people purchasing aftermarket seal kits from ebay. Anyone have any experience with
this SFK kit
? Hope so anyway because I just ordered one.
There is also a kit from Canada. ..
Maybe too late but heck, I'll order them both if necessary.
What say ye?
What say ye?
Last edit: 11 Aug 2015 19:49 by Nessism.
The following user(s) said Thank You: undiablo
- Tyler
Re: KZ750/4 & KZ650 Crankshaft Seal
11 Aug 2015 21:43
I have not used SKF parts for the 650, but have used their stuff before. You should be just fine with their parts. I would have used them if that kit was available when I did my 650.
If I remember the crank seals were directional, and only one side was still available from Kawasaki. I put the same seal both sides one was running backwards. Have no issues with it 6 years later.
"74 Yamaha DT 400 Enduro
- DFIGPZ
13 Aug 2015 21:39
I may have a genuine NOS if you provide part # needed.
1984 750 Turbo
13 Aug 2015 21:55DFIGPZ wrote: I may have a genuine NOS if you provide part # needed.
Part number is in my original post.
14 Aug 2015 14:19
I got good parts from Rusty Riders.
- DFIGPZ
14 Aug 2015 16:40
I have NOS 92049-1090 Stator Side Crank seal if your number supersedes to it 92049-1090 from 750 turbo.
1984 750 Turbo
16 Aug 2015 06:53
That's interesting info about the turbo seal. Wonder if the diameter is the same and wonder why Kawasaki doesn't suggest it as an alternate.
At any rate, the SFK seals arrived and they look pretty good. Rubber is nice and soft; not just some leftover stock from 20 years ago. The crank seals have a lip on the outside OD to match with the groove in the case, and the seals inner lip has spiral flutes to keep oil inside. The RH and LH seals are different since the rotation is in opposite directions. Same as the OE seals. Time will tell how durable these things are but they pass the sniff test for now.
16 Aug 2015 07:23
Sounds good to me.
