kz1000J3 broken camchaft cap
- Oskari72
31 Jul 2015 05:12
Hi
I hate to admit that I really broke one of the camchaft caps when putting it on. I quess those are machined with the cylinder head and now I need the whole thing. Please tell me what year models have the same cylinder head.!!
HELP...
Oskari
HELP...
Oskari
Oskari
KZ1000J3
KZ1000J3
Re: kz1000J3 broken camchaft cap
31 Jul 2015 05:26
Show a picture of the cap. Depending on how it's broken it may not matter much at all. Ed
31 Jul 2015 06:30
There was another one here a few months ago. It was glued together. BAD IDEA. It should have been welded. They are a matched set to the head. You could get another one, take it to a machine shop and have it fitted or have the one you have welded and put it on.
- barney
31 Jul 2015 06:40
If you find a replacement it will need to be line bored to the head before you try and use it
31 Jul 2015 06:46
if you can get some other caps some
www.plastigaugeusa.com/how.html
will tell you if you can use em or not without having them machined.
The following user(s) said Thank You: PLUMMEN
- Tyrell Corp
31 Jul 2015 07:41
Yup, years ago I had too many 550 engines in bits, some cam caps got mixed between a couple of heads. as they are numbered, by removing the valves and putting one cap on at a time I could feel the difference. Not ideal, now I dot punch mark them .
31 Jul 2015 07:55 - 31 Jul 2015 07:57
Rebuilding my 67 Pontiac Le Mans 326 motor, I had a guy washing parts for me. I told him not to mix up the rod bearing caps. He did. I sent him home. I wanted to murder him! Putting it together I had to go with the witness marks from when they were machined. Fired it up, nice and smooth, then it slowed down and froze.
I was so disgusted, that car sat for ten years until I scrapped it. Wish I would have kept it. :pinch:
Old saying "You pay peanuts, you get monkeys". :whistle:
Last edit: 31 Jul 2015 07:57 by SWest.
- Mcdroid
- Gone Kwackers
31 Jul 2015 08:41swest wrote: Old saying "You pay peanuts, you get monkeys". :whistle:
I like it.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
31 Jul 2015 08:55
When I was wrenching on bikes, I'd get machines that some expert had worked on. I'd take it in depending on how bad it was. Sometimes I'd send them away. :dry:
I went back to pounding nails when I got my kids, then after a while I started my handyman service. One of my competitors had a slogan; We fix what your husband broke. :lol:
Wish I had though of it. :whistle:
31 Jul 2015 10:29
I guess I went a little off topic. What is the decision on the cam cap?
- missionkz
31 Jul 2015 16:40I also want to see how it is broken first....swest wrote: I guess I went a little off topic. What is the decision on the cam cap?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
31 Jul 2015 17:13
I'm not sure about KZ's but with Suzuki GS's, which also have line bored cam caps, you can replace lost/damaged caps with another one without issue (typically). I'd try a new cap before scrapping the head. It might help to have a couple to choose from.
