kz1000J3 broken camchaft cap
  • Oskari72
  • Oskari72's Avatar Topic Author
31 Jul 2015 05:12
#683570
Hi
I hate to admit that I really broke one of the camchaft caps when putting it on. I quess those are machined with the cylinder head and now I need the whole thing. Please tell me what year models have the same cylinder head.!!
HELP...
Oskari
Oskari
KZ1000J3
Re: kz1000J3 broken camchaft cap
31 Jul 2015 05:26
#683573
Show a picture of the cap. Depending on how it's broken it may not matter much at all. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Jul 2015 06:30
#683582
There was another one here a few months ago. It was glued together. BAD IDEA. It should have been welded. They are a matched set to the head. You could get another one, take it to a machine shop and have it fitted or have the one you have welded and put it on.
  • barney
  • barney's Avatar
31 Jul 2015 06:40
#683584
If you find a replacement it will need to be line bored to the head before you try and use it
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
31 Jul 2015 06:46
#683587
if you can get some other caps some
www.plastigaugeusa.com/how.html
will tell you if you can use em or not without having them machined.
The following user(s) said Thank You: PLUMMEN
  • Tyrell Corp
  • Tyrell Corp's Avatar
31 Jul 2015 07:41
#683588
Yup, years ago I had too many 550 engines in bits, some cam caps got mixed between a couple of heads. as they are numbered, by removing the valves and putting one cap on at a time I could feel the difference. Not ideal, now I dot punch mark them .
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Jul 2015 07:55 - 31 Jul 2015 07:57
#683591
Rebuilding my 67 Pontiac Le Mans 326 motor, I had a guy washing parts for me. I told him not to mix up the rod bearing caps. He did. I sent him home. I wanted to murder him! Putting it together I had to go with the witness marks from when they were machined. Fired it up, nice and smooth, then it slowed down and froze. :angry: I was so disgusted, that car sat for ten years until I scrapped it. Wish I would have kept it. :pinch:
Old saying "You pay peanuts, you get monkeys". :whistle:
Last edit: 31 Jul 2015 07:57 by SWest.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
31 Jul 2015 08:41
#683595
swest wrote: Old saying "You pay peanuts, you get monkeys". :whistle:
I like it. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Jul 2015 08:55
#683596
When I was wrenching on bikes, I'd get machines that some expert had worked on. I'd take it in depending on how bad it was. Sometimes I'd send them away. :dry:
I went back to pounding nails when I got my kids, then after a while I started my handyman service. One of my competitors had a slogan; We fix what your husband broke. :lol:
Wish I had though of it. :whistle:
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Jul 2015 10:29
#683601
I guess I went a little off topic. What is the decision on the cam cap?
  • missionkz
  • missionkz's Avatar
31 Jul 2015 16:40
#683656
swest wrote: I guess I went a little off topic. What is the decision on the cam cap?
I also want to see how it is broken first....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Nessism
  • Nessism's Avatar
31 Jul 2015 17:13
#683661
I'm not sure about KZ's but with Suzuki GS's, which also have line bored cam caps, you can replace lost/damaged caps with another one without issue (typically). I'd try a new cap before scrapping the head. It might help to have a couple to choose from.
