"Thar she blows! " Tyrell's GPz550
- Tyrell Corp
26 Jul 2015 13:53 - 26 Jul 2015 14:17
My 81 Gpz needed some attention, the primary starter clutch was slipping and I was planning to upgrade to forged wiseco 615cc pistons probably with a big valve cylinder head and base circle skim fast road cams.
Recently it develoed what sounded like a top end rattle which got a lort worse over the course of the next few hundred miles. What was a tired and slightly smoky engine got a lot worse....I knew I was on 99% by then.
This is the bike with slipping starter rattly motor and smokey exhuast.
much worse now -totally stufed.
This is what i found...
wrist pin fine
Bore not so happy, scored also on the other side
Piston boss badly cracked
I think i know what went wrong here. no probs, the engine was coming out and the block was coming off anyway. Call it routine maintenance. :laugh:
Attachment 143794187523364.jpg not found
wrist pin fine
Attachment 1437941875233642.jpg not found
Attachment 1437941875233641.jpg not found
Attachment 1437941875233643.jpg not found
Last edit: 26 Jul 2015 14:17 by Tyrell Corp.
Re: "Thar she blows! " Tyrell's GPz550
26 Jul 2015 15:06
Looks like the piston was flopping from side to side.
- Tyrell Corp
27 Jul 2015 17:43
It sounded just like the wrist pin rattling in the top end, it got worse from just noticeable to really bad within a few hundred miles. The pin looks fine, half of one piston circilp was missing and the pin was floating far too much beyonfd the circlip groove . The worst damage to the top of the cylinder wall is quite localised.
I think it might be detonation damage. I was fooling around with a defective advancer and got some severe pinking open throttle on the highway. I wanted to feel the difference and knew the pistons were on their last leags.
- harm
- Tom
28 Jul 2015 07:25
Bummer, So you will probably go thru the bottom end too?
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- Tyrell Corp
28 Jul 2015 12:52 - 28 Jul 2015 12:56
Probably not, all the shrapnel fellto the bottom of the sump. I might split it anyway, I can't remeber if I fitted a new primary chain or not. Bottom end all ok it seemed ok when I built it .
Attachment 0452.jpg not found
Last edit: 28 Jul 2015 12:56 by Tyrell Corp.
