"Thar she blows! " Tyrell's GPz550
  • Tyrell Corp
  • Tyrell Corp's Avatar Topic Author
26 Jul 2015 13:53 - 26 Jul 2015 14:17
#682836
My 81 Gpz needed some attention, the primary starter clutch was slipping and I was planning to upgrade to forged wiseco 615cc pistons probably with a big valve cylinder head and base circle skim fast road cams.
Recently it develoed what sounded like a top end rattle which got a lort worse over the course of the next few hundred miles. What was a tired and slightly smoky engine got a lot worse....I knew I was on 99% by then.
This is the bike with slipping starter rattly motor and smokey exhuast.
much worse now -totally stufed.
This is what i found...
Attachment 143794187523364.jpg not found
wrist pin fine
Bore not so happy, scored also on the other side
Attachment 1437941875233642.jpg not found
Attachment 1437941875233641.jpg not found
Piston boss badly cracked
Attachment 1437941875233643.jpg not found
I think i know what went wrong here. no probs, the engine was coming out and the block was coming off anyway. Call it routine maintenance. :laugh:
Last edit: 26 Jul 2015 14:17 by Tyrell Corp.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: "Thar she blows! " Tyrell's GPz550
26 Jul 2015 15:06
#682847
Looks like the piston was flopping from side to side.
  • Tyrell Corp
27 Jul 2015 17:43
#683051
It sounded just like the wrist pin rattling in the top end, it got worse from just noticeable to really bad within a few hundred miles. The pin looks fine, half of one piston circilp was missing and the pin was floating far too much beyonfd the circlip groove . The worst damage to the top of the cylinder wall is quite localised.
I think it might be detonation damage. I was fooling around with a defective advancer and got some severe pinking open throttle on the highway. I wanted to feel the difference and knew the pistons were on their last leags.
  • harm
  • harm's Avatar
  • Tom
28 Jul 2015 07:25
#683107
Bummer, So you will probably go thru the bottom end too?
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
  • Tyrell Corp
28 Jul 2015 12:52 - 28 Jul 2015 12:56
#683153
Probably not, all the shrapnel fellto the bottom of the sump. I might split it anyway, I can't remeber if I fitted a new primary chain or not. Bottom end all ok it seemed ok when I built it .
Attachment 0452.jpg not found
Last edit: 28 Jul 2015 12:56 by Tyrell Corp.
