NOOB-1st Post, Timing Advance question
  • conundrum
  • conundrum's Avatar Topic Author
Re: NOOB-1st Post, Timing Advance question
19 Jul 2015 19:10
#681708
More info after further inspection: I will have to replace the entire timing advancer. When breaking free all the rusted parts I managed to break off the two small tabs on the swing arms that go inside the center shaft that actually advance the timing. Partzilla sells it for $91.XX (21148-1024) Anyone have one laying around?
19 Jul 2015 19:42 - 19 Jul 2015 19:42
#681717
Before ordering - call Partzilla first to verify availability. I suspect you will find the part is no longer available. Ed
Last edit: 19 Jul 2015 19:42 by 650ed.
  • bountyhunter
  • bountyhunter's Avatar
19 Jul 2015 20:38
#681721
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
conundrum wrote: More info after further inspection: I will have to replace the entire timing advancer. When breaking free all the rusted parts I managed to break off the two small tabs on the swing arms that go inside the center shaft that actually advance the timing. Partzilla sells it for $91.XX (21148-1024) Anyone have one laying around?
The following user(s) said Thank You: Randombeat
  • bountyhunter
19 Jul 2015 20:41
#681722
You should also contact the online dismantlers.
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Jul 2015 21:43
#681727
These things are popping up almost every day.
  • Tyrell Corp
  • Tyrell Corp's Avatar
20 Jul 2015 04:03
#681746
There is a four digit code on mine, from memory 1016 on the 550 and 1020 on the 1100.
Might help you with identification.
