- Thank you received: 292
A Thread thread ! (Help needed)
- davido
Top left;
Also,does anyone have a smart idea for getting a drill 'straight' onto the hole,I would appreciate it
Thanks
(J Model engine and damage to casing probably came from the sprocket bolt coming loose)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Thank you received: 2749
I believe the threads go through the case there anyway. Closer pics would help.
Steve.
- kaw-a-holic
- Thank you received: 249
Davido, at this point I would go with the same depth as the one that does pass through, 16mm. Or go as far as the recess under that location. My thought on this is that there is not a lot of stress at this location. It does not require a lot of torque. All you have to hold is the new hydraulic clutch plate your building. It does not have any more pressure on it than the OEM set up, the hydraulic set up as to apply the same amount of pressure to engage the clutch as the worm gear did.
I agree with Steve that removing the starter may make it easier to tap and thread. Like Steve said, I would try just tapping it with the existing hole. Use cutting oil, make a couple of turns, back it out, blow out the hole clean the tap, repeat until its done. If you remove the starter you should have enough room to use a box end wrench on the tap.
Hope it works out for you David.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
- davido
I have taken out the starter and the genny cover but the distance is still too long for a regular drill (about 14/15mm I think) .I was able to find a ( cheap) drill with a hexagonal shank along with a long bit holder I could get the drill on, centered and parallel. For some reason (low quality drill?) I was only able to drill in about 10mm or so,then I hit something solid. I didnt want to force it,so I left it like that.I tapped it out and fitted a Helicoil with some thread lock. Next day,I put the side cover on,tightened it down a bit and the coil pulled straight out!
Looking at the tap that came with the helicoil,the cutting part dosnt really start until 7 or 8mm in so my coil had nothing to bite on.
So,plan D is to forget about liquid metal and helicoils or timeserts. I want to drill the hole very oversize maybe M8 or M10,whatever I can get away with. Tap it,thread in an alminium bolt,whack it off flush and drill/tap that.It should be a lot more secure.
I want to go in as deep as I safely can,hence the question 'How deep should this hole be?'
Im pretty sure the threads dont go right through on this (J model) engine. On earlier ones I believe it does and I really dont want to run it as is because Im fitting an hydraulic clutch shfter thing so I need all the mounts.
P.S.Any Idea how deep this hole should be?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Thank you received: 2235
To get maximum threads, use a bottoming tap. They are more of a challenge to get started perfectly straight, but they will make threads almost to the bottom of the hole. Alternately, you can start threading with a regular, pointy tap, then finish with the bottoming tap.
- davido
OK,Just checked the parts page and yes,it seems there are 2 locating dowels on the cover but they seem to be on the bottom 2 mounts.
Which would explain why the lower right mount looks a bit big but dosnt help with the depth measurement I need
Thanks anyway.Good to know.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- OnkelB
- Thank you received: 80
davido wrote: Could do but it would be a lot easier if someone just measured it and said,'This hole should be xxxmm deep'
Guess what, I just tore my spare J (GPz 1100) engine down this weekend - went out and measured, that hole is 22 mm deep.
And yes, the two locator dowels for the sprocket cover are on the bottom bolts, none in the hole in question.
77 KZ 650 B1, 82 GPz 1100 B2.
