GPZ1100 Cylinder Question
  • KraZyRIDER
  • KraZyRIDER's Avatar Topic Author
23 Jun 2015 21:14
#678027
...I'm looking at a 1981 GPz1100 engine to pick up as a spare. It was over heated many years ago and scored the cylinders. Everything else looks solid, except for the cylinders and pistons. Plans for the motor was to go bigger, but that never happened. Now it's for sale.
...I do not want to go oversized, I would like it to remain stock. My question is, are there cylinders from other models that will work on the '81 GPz1100? I would naturally prefer the GPz cylinders, but will use any that will work if I cannot locate the GPz set up.
...Better yet, anyone have a set of GPz1100 cylinders to sell? :laugh:
...Any insight would be greatly appreciated. Thanks!
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • KraZyRIDER
Re: GPZ1100 Cylinder Question
01 Jul 2015 10:59
#678959
...Anyone have any idea? Anyone?
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • missionkz
  • missionkz's Avatar
01 Jul 2015 11:18
#678961
Photos of the cylinders and pistons?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
The following user(s) said Thank You: KraZyRIDER
  • etbike3135
  • etbike3135's Avatar
01 Jul 2015 15:01
#678984
Any 1100 cylinder is the same from 82 to 85.
1973 Kawasaki Z1
18 years in dragbikes
The following user(s) said Thank You: PLUMMEN, KraZyRIDER
  • dapro
  • dapro's Avatar
  • 1981 GPZ1100 1982 KZ100J 1978 Cb550
01 Jul 2015 19:55
#679040
3135 Go to the APE web page they have a list of what cylinders work with what year bikes. They also do really good head work and cylinder boring
  • KraZyRIDER
01 Jul 2015 21:31
#679058
missionkz wrote: Photos of the cylinders and pistons?
...Thanks. I'm all for photos, but I don't think that would do in this case.
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • KraZyRIDER
01 Jul 2015 21:32
#679059
etbike3135 wrote: Any 1100 cylinder is the same from 82 to 85.
...Cool! I was hoping that would be the case. Thanks!
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • KraZyRIDER
01 Jul 2015 21:33
#679060
dapro wrote: 3135 Go to the APE web page they have a list of what cylinders work with what year bikes. They also do really good head work and cylinder boring
...Really! I'll check it out. Thanks!
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • Tyrell Corp
  • Tyrell Corp's Avatar
03 Jul 2015 04:05
#679197
The GPz11's did suffer from high oil consumption, apparently Kawasaki had the idea to bore the barrels first then press into the block causing distortion. Mine was really powerful to ride but used to use a lot of oil, that's the only reason I'm going 1170.
Good info from Z power uk:
...NOT SINCE THE Z750 TWIN HAD WE HAD FAULTS. PAINTING FAULTS, GEARBOX FAULTS, ELECTRICAL FAULTS, AND WORST OF ALL, OIL CONSUMPTION FAULTS. THE Z1 DID NOT USE GREAT AMOUNTS OF OIL. EVERYBODY KNEW THIS. KAWASAKI KNEW THIS. THE WHOLE WORLD KNEW THIS. THE Z1 ENGINE WAS BULLET PROOF. RUSS COLLINS, VANCE AND HINES AND THE REST OF THE DRAG STRIP LADS PROVED THIS. SO WHAT WAS HAPPENING ?.
KAWASAKI DECIDED THAT 500 MILES TO A LITRE WAS ACCEPTABLE. 5000 MILES TO A LITRE WOULD HAVE BEEN ACCEPTABLE BUT NOT 500 MILES. A TRIP TO EUROPE WOULD COST YOU MORE IN OIL THAN IN PETROL.!! OH DEAR ! ALL WAS NOT WELL IN THE KAWASAKI CAMP.
www.z-power.co.uk/merchantmanager/view_information.php?pId=35
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Jul 2015 07:27
#679228
They also went to steel valve guides in the early KZ 1000's. Oil burning issues forced them to go back to brass.
