fouled plugs?
  • oldsguy
  • oldsguy's Avatar Topic Author
fouled plugs?
19 Jun 2015 05:14 - 19 Jun 2015 05:16
#677240
#1,3,4 plugs black sooty but dry, and #2 plug clean and tan...what may be causing this? Also bike will not idle..and stumbles at low rpm. Cleaned and sealed tank, replaced inline filters, and fresh gas. On 76 900
Last edit: 19 Jun 2015 05:16 by oldsguy.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: fouled plugs?
19 Jun 2015 09:02
#677267
Time for a tuneup, Carbs clean, check sync, Valve train ,check shim clearance , chain adjustment, timing, Compression test, Ignition , Points??? Factory manual ?
Dave B) B) B)
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • oldsguy
Re: fouled plugs?
19 Jun 2015 10:05
#677274
Thanks, just ordered shop manual..plugs are new, still has points, wires in good condition...
  • Moderator
  • Moderator
Re: fouled plugs?
19 Jun 2015 10:22
#677275
Make sure it is a Kaw Factory Manual .
These bikes are easy to work on and can be a enjoyable time bonding with your scooter.
Just remember to triple check everything and NEVER assume a part is good or installed properly without checking it. Age alone , and who else has had their hands in the bike since it was built can explain many issues ..
Dave B) B) B)
The following user(s) said Thank You: oldsguy
  • oldsguy
Re: fouled plugs?
19 Jun 2015 10:50
#677277
Thanks dave, ptoblem is..guy before me said top rnd was done..not sure what..so im kinda on my own guessing. Just trying to get past this fouling issue and enjoy it before tearing it apart.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: fouled plugs?
19 Jun 2015 11:10
#677278
Check you valve adjustments to rule that out. Often the gasket can be reused. Just bop it with a rubber mallet, slide a blade around it ot the top and reseal with Copper silicon.
  • oldsguy
Re: fouled plugs?
19 Jun 2015 15:45
#677316
Checked compression cyl # 1-95, 2-100, 3-90, 4-85 lbs...bike started and ran with plugs 2,3 out seperately. Bike has 52000 miles not sure if its ever been rebuilt. Im assuming its in need of complete rebuild. Did test just turning bike over, read somewhere its supposed to be done at wot?
  • missionkz
  • missionkz's Avatar
Re: fouled plugs?
19 Jun 2015 15:57
#677317
Yes... Check valve lash first and correct that if they are too tight.
do it with no plugs. Wide open throttle.
Below 100psi is a sign It is well worn. But do it again with a little shot of oil in each cylinder and hold the throttle wide open
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: fouled plugs?
19 Jun 2015 17:22
#677332
If it's been sitting the compression could come up if running right. People don't want to do the valve adjustments, "too much hassle."
A very common issue.
