1977 KZ1000 valve check/adjustment
  • A1rider
  • A1rider's Avatar Topic Author
17 Jun 2015 09:06
#676943
1st time posting here. Im checking the valves on my kz1000. IS the correct position of the cam lobe (Highest point) should be 180 degrees from the shim/valve when inserting the gauge? With the lobes 180 away only 3 (.003 fits perfect) appear to be in spec. all others are too tight to insert the .002 gauge. If the lobe is say 45 degrees I can fit gauge in (is that the wrong position to check clearance from?) thanks
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1977 KZ1000 valve check/adjustment
17 Jun 2015 10:22
#676949
Do you have a manual?
  • missionkz
  • missionkz's Avatar
17 Jun 2015 10:43 - 17 Jun 2015 10:43
#676952
The factory service manual doesn't say anything about pointing the lobes away from the valve. As a matter of fact , it says to use the marks on the camshaft gears and align them with the top of the head.
That implies to me there are take up ramp spaces in the cam profile that are not taken into consideration by pointing the lobe 180 degrees from the valve.
However, I know a lot of owners do it with the 180 degree anyhow....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 17 Jun 2015 10:43 by missionkz.
  • A1rider
17 Jun 2015 12:56
#676992
thanks guys, I do have the Clymers manual and it didnt say much. the video on KZR homepage they say" point the lobe directly away from valve/lifter" so Im assuming thats 180 off.
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Jun 2015 13:18
#676994
I set mine a touch loose. A Climer is a one fits all. Best the have a manual meant for your bike. I have one but ignore most of what it says.
I have one just for the Z1's. All my manuals were stolen by the local Meth heads. I was forwarded this by one of our members.
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Jun 2015 13:20
#676995
Wasn't able to upload the PDF file. If anyone needs it, PM me and I will forward it via e-mail.
  • Kapahulu
  • Kapahulu's Avatar
17 Jun 2015 13:43
#676998
A1 Rider yes pointing the cam lobe 180 degrees away from the shim should work.
2strokeworld.com
The following user(s) said Thank You: A1rider
