Manual Tensioner Instructions - concerned
- Pontiacdude210
16 Jun 2015 09:45
These are the instructions that came with my manual CCT. Something doesn't seem right. I thought the cam covers have to be in place to install a tensioner? But then how do I know how tight to go with it?
-1980 KZ550C Viper Red, Black Fenders
- Pontiacdude210
Re: Manual Tensioner Instructions - concerned
16 Jun 2015 09:47
I also have a manual OEM tensioner from an earlier 650. Will that work or be a better option? The stocker on my 80 that's all automatic concerns me.
16 Jun 2015 10:51
I don't trust those instructions.
- zed1015
16 Jun 2015 11:16
Do it like this, works every time and no need to remove the cam cover.
Get a 17mm wrench on the ign side of the crank.
Rotate the crank clockwise with the wrench so that all the slack is taken up at the front,
Now by gently rocking the crank ( first anticlockwise and back ) with the wrench ( not enough to move the pistons ) you will feel the slack in the camchain on the tensioner side.
Whilst rocking the crank you need to simultaneously wind the APE tensioner in by HAND until the amount the wrench can be moved is reduced and you can barely feel any give in the chain. ( As you rock the crank the tensioner screw will rotate very easily with your fingers )
Once that point is reached, rotate the crank a few times , re-check and then lock off the tensioner.
You should now be good to go.
The following user(s) said Thank You: 0Z.Z1R Mk2, Pontiacdude210, bluezbike, 80B4, Randombeat
- Pontiacdude210
18 Jun 2015 23:27
Thanks man. I got 'er done! First 2 times I was gun shy and left it too loose. Hell of a noise. Next time I dorked up the jam nut and it came loose. Last time through, I turned by hand until the crank got noticeably harder to turn. Then I cranked the jam nut down good. Nice quiet happy chain. Thanks.
