1979 kz1000
  • 1979kz1000
  • 1979kz1000's Avatar Topic Author
1979 kz1000
08 Jun 2015 21:19
#675814
When not using throttle bike dies. When bike dies battery has lost its charge. Any ideas
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1979 kz1000
08 Jun 2015 21:22
#675815
New battery. Have you tested the charging system. Do you have a manual? Pics?
  • 1979kz1000
Re: 1979 kz1000
11 Jun 2015 01:48
#676112
Sorry I took so long to respond I have not tested the charging system how do I do that? Battery is new. I'd the there any stores that sell the manuals? Thanks
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
Re: 1979 kz1000
11 Jun 2015 03:10
#676113
Check with Z1Enterprises,Marion,New York, they sell Manuals, many auto parts stores can order Clymer manuals. As far as checking the charging system, if you know how to use a VoltOhm meter, start bike ,Let it warm up, have someone keep throttle at around 4,000 rpm , look at Volt reading on battery terminals with the Volt Meter, should be around 14-16 volts , at least that's how manual says to check my '75.900. Just my .02......
You also may have a loose or corroded connection .I am sure Steve West or 650Ed or someone else may have more idea's.
Good Luck and I hope you find the problem, Let us know how it turns out!
Regards
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1979 kz1000
11 Jun 2015 08:33
#676142
I have a Climer here :sick: , it covers 73-80 bikes. I use for reference. Best if you get a factory one. Try eBay. Has it been sitting? Pics?
  • 1979kz1000
Re: 1979 kz1000
12 Jun 2015 02:28
#676264
I'm not too positive on how long it has been sitting what parts of the bike should I take pics of?
And thanks Ed I'll try that stuff this weekend and let you know
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1979 kz1000
12 Jun 2015 07:41
#676286
The battery wiring, regulator etc.
