Engine Gasket Removal Tips?
  • 83KZ750LTD
  • 83KZ750LTD's Avatar Topic Author
08 Jun 2015 12:32
#675736
Ok whats the trick for removing old head and base gaskets? My gaskets are cooked on and I cannot get them off with razor blades, steel wool, and acetone. I still haven't even got to the cooked on crap at the base gasket on the lower end.... :angry:
1983 KZ750-F1 LTD - 8000 miles - 2/2015 - Head gasket time!
  • DobbinsCMA
  • DobbinsCMA's Avatar
Re: Engine Gasket Removal Tips?
08 Jun 2015 13:02
#675738
Don't use razors. I found that 3M rubber bristle pads that are circular which screw onto a power drill to work the best (there are different colors for hardness, I used yellow). I used brake cleaner then rub them off with the pad. It takes them off but doesn't mess up the aluminum. One bad nick with a razor can cause an oil leak. The plastic razor thing is good but not so good for baked on gaskets. Hope it works.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
08 Jun 2015 13:03
#675739
3M RoLoc (or Harbor Freight knockoff) green and read pad along with WD-40 and a 6 pack of Corona Light. Also had a sharpened piece of plexiglass for the big chunks.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
The following user(s) said Thank You: DobbinsCMA
  • DobbinsCMA
08 Jun 2015 13:05
#675740
Yes that's what they are called!
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Jun 2015 13:23
#675749
A heat gun can help too. If it's permatex, all bets are off.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
08 Jun 2015 14:04
#675754
Be very careful with the roloc discs, they can eat aluminum.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • bluej58
  • bluej58's Avatar
08 Jun 2015 16:23
#675773
I like to use these things ; www.harborfreight.com/carbon-gasket-scraper-98507.html
Not necessarily from H.F. but this type of scraper,all the auto parts stores have them very easy on the hands.
They come petty dull so before I use one I take a file to the edge and get it real sharp.
Be real careful not to cut your self,
I like to do a side to side wiggle with it and an easy forward motion.
After your get most of the gasket off you can go to a razor blade and scotch brite to finish it off
JD
78 KZ1000 A2A
  • 83KZ750LTD
09 Jun 2015 06:27
#675848
This is easily the most frustrating engine that I've ever worked on. I've worked on many other engines, large and small. But this one is the devil! I've never had gaskets stick like these do. Maybe I've just been lucky...
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jun 2015 06:37
#675850
And it leaked too right? :whistle:
  • 83KZ750LTD
09 Jun 2015 06:42
#675851
This Kawi leaked like crazy. My pants were always covered in oil. The last time I rode it, it lost a nearly a quart in 40 miles. I decided that was a bit much... :)
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
09 Jun 2015 06:54
#675853
One point you should consider once you have a clean mating surface and are ready for assembly is how to prevent the gaskets from getting cooked on in the future. Myself, I have used copper gasket spray on some of my gaskets and a film of waterproof grease on my base cylinder block gasket. My hope is that if I have to go in again for any reason, removing old gaskets will not be an issue.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 Jun 2015 06:55
#675854
Yeah the O ring around the cam chain always leaked. I'd put in a new one, it would start leaking. Two years ago I bought a kit from Z1, I wanted a copper head gasket but was talked out of it. My fault, I knew better. :whistle: In less than a year it started leaking BAD. I pulled the head and it was hard and broken in three places! NOS rubber. :( This time I put in a one piece head gasket for a early Z1. Filled the O ring groove, NO LEAKS. I was concerned I might have detonation issues because of the smaller gasket. 1015 bore and a 903 gasket. About 10,000 miles, no problems. B) I have a copper one now, just waiting on a piston, STILL. :angry:
