'83 zx1100-A1 clutch parts missing - please help
  • My77gmc
  • My77gmc's Avatar Topic Author
05 Jun 2015 22:12
#675466
See this exploded view from Kawasaki
www.kawasaki.com/Parts/DownloadDiagramPd...&modelcode=ZX1100-A1
In the lower left, there are components between the clutch release mechanism and the clutch itself.
There is a group of parts including
600
92043
92022
92015
92026-A
And a group of parts including
92022
92015
13116-A
92046
92022-C
92026-B
Are both of these inside my engine or is this two different assemblies used to connect the clutch release pushrods to the clutch operating plate?
I need to verify these parts are there, will these be accessible with removal of the clutch operating plate?
A bit of back story, this gpz1100 engine is installed in my 4x4 chain driven mud buggy. I bought it not running from a friend for a good price, and I've been going through it slowly over the past month or so. When I got it the right side engine cover was missing and the clutch operating plate and the friction plates and steel plates were all missing. I got the engine running with a new fuel pump and some digging around in the hacked apart wiring harness. I found replacements for everything I knew of, but I don't think I had a bearing and a pusher in there and I'm not sure if what's in the exploded view would have been in between the clutch basket and the operating plate or if they would be behind the clutch basket(under the self locking nut).
Any help would be appreciated.
  • My77gmc
Re: '83 zx1100-A1 clutch parts missing - please help
06 Jun 2015 08:56 - 06 Jun 2015 08:59
#675498
Further investigation reveals, the first grouping is apparently for 84 models, the second grouping is for 83 models.
Please correct me if I'm wrong
I found the parts I needed on partzilla.com
13116-1102 ROD-PUSH,CLUTCH 13116-1102 $25.84 Supersedes 13116-A in the factory manual
92022-1463 WASHER,15.1X29X1.0 92022-1463 $2.25
92046-1052 BEARING-NEEDLE,AXK110 92046-1052 $6.84
Plus $16 express usps to alaska
Last edit: 06 Jun 2015 08:59 by My77gmc. Reason: Aliens abducted my iPad and I had to battle across the galaxy to return and correct my autocorrect typos. G'Day!
  • My77gmc
08 Jun 2015 07:27 - 08 Jun 2015 07:27
#675711
After calling to verify my order there is still question as to which parts should be used.
Can anyone help? I just need to know if I need to order both groups of parts or if I need to order either or.
Please help, I don't have the original pieces to verify or compare...and I can't seem to find any Kawasaki folks here in alaska that are familiar.
Thanks!
Last edit: 08 Jun 2015 07:27 by My77gmc.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Jun 2015 08:09
#675714
Look on eBay or try The Old Kaw Man.
  • martin_csr
  • martin_csr's Avatar
08 Jun 2015 08:19 - 08 Jun 2015 12:38
#675715
Try comparing the parts at Kawasaki.com --- the 83 & 84 ZX1000-A1/A2 models are listed under GPz.
From what I was able to figure out, the parts used on the 83 are only in the list for the A1 & the stuff for the 84 are only in the list for the A2. So I think your bike should have the 1st group of parts but not the second group. I think the parts shown within the small box in the diagram are for the 84 model. ???
Kawasaki.com -->> Owner Center -->> Parts diagrams -->> Motorcycle -->> Year-->> GPz -->> ZX1100-A
Last edit: 08 Jun 2015 12:38 by martin_csr.
  • My77gmc
09 Jun 2015 11:39
#675889
Thanks for the input!
After comparing the two parts lists, everything is the same except the ball, pushrod pin and clutch spacer on the 83 model is replaced with the clutch pushrod, needle bearing flat washer and clutch spacer on the 84 model.
I went ahead and ordered both, as the needle bearing should wear less and should interchange...or so I'm told, as long as I install all those parts listed n the 1984 parts list.
Correct me if that's wrong please, and thanks again!!
  • martin_csr
10 Jun 2015 07:41
#675980
I think everything else is the same, so you could probably use either group of parts on either model --- the 84 stuff on the 83, or vice versa.
