1977 kz 1000 bad counter shaft bearing removal?
  • Goalieguy35
  • Goalieguy35's Avatar Topic Author
  • JJ
04 Jun 2015 08:59
#675210
Hi everyone, ive been working on putting a 77 kz 1000b together and i picked up an engine that had good compression so i bought it not knowing the condition of the bottom end. when i got the motor in the frame i took the cover off the shift shaft/sprocket cover i noticed my counter shaft had alot of play... :( my question is how big a job is that? can i pull the cover with the countershaft seal off and pull the bearing out that way or would i have to do a whole engine tear down and split the cases....?
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
  • spdygon
  • spdygon's Avatar
Re: 1977 kz 1000 bad counter shaft bearing removal?
04 Jun 2015 11:00
#675221
Sorry to hear that....but u need to split the cases in order to get the shaft out.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Jun 2015 16:02
#675257
There is a pin holding the bearing in.You have to split the cases. You need a manual or you can break them.
  • Goalieguy35
  • JJ
07 Jun 2015 19:49
#675669
thank you guys! too bad because it runs so good...
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Jun 2015 21:54
#675678
Is the sprocket loose. It has to be torqued you know.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Jun 2015 21:59
#675680
I was wrong about the pin, that's on the other side. The output bearing has a ring to keep it in place. I switched my tranny without taking the head off. You just have to remember the few bolts on the top of the case. The rest are on the bottom. Two day job for one man. Needed help getting it back in.
