78 750 KZ primary chain replace
  • Janosh
  • Janosh's Avatar Topic Author
21 May 2015 20:36 - 22 May 2015 15:38
#673083
I CANT FIGURE OUT HOW TO GET THE PRIMARY CHAIN OFF THE CRANKSHAFT. DO i HAVE TO SPLIT THE BOTTOM OF THE CRANK CASE?
I tried replying to several of these posts, but they don't appear to be coming through, so I'll try editing the original.
The downloaded manual doesn't go into much detail. My originals burned up in a shop fire back in 01 along with 2 other 750 twins.
I had adjusted the timing chain, but I can no longer get the timing past retarded and I cold hear chain slap, so I put it away about 5 or 6 years ago. Been riding my 85 XL 600 enduro. Grandson wants to get it going so on my suggestion he got a new primary chain. Looks like I was wrong, Thank you for the enlightenment.
Last edit: 22 May 2015 15:38 by Janosh. Reason: tried replying to inquires but they aren't coming through
Re: 78 750 KZ primary chain replace
21 May 2015 20:48
#673087
Do you have the Kawasaki Service Manual? If not, you need it before you break your engine down. Also, in it you will see how to check the cam chain to see if it is within service limits. What led you to believe you need to replace it? How many miles are on the bike? Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 May 2015 21:06
#673089
While you're in there, you might as well check the tranny too. Big job. :unsure:
The following user(s) said Thank You: Janosh
  • zed1015
  • zed1015's Avatar
21 May 2015 23:08
#673097
Yes! you need to split the engine.
The primary chain is good for 75,000 miles so are you sure it needs replacing ?
  • baldy110
  • baldy110's Avatar
22 May 2015 08:45
#673144
I will assume you hare talking about the 750 twin. The primary chains on most motorcycles hardly ever needs replacing. They are robust and can take a lot of abuse. For example my 78 KZ650 which I bought new has over 150,000 miles on the bottom end of the engine and is still fine. I abused the crap out of the thing in my younger days, lots of wheelies, burn outs, ect.. Again what makes you think the chain is bad?
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
22 May 2015 10:03
#673152
Stop YELLING at me !!! ( I'm case sensitive!)
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 May 2015 11:36
#673165
He must be thinking it's like a Hog. Separate primary and tranny. :lol:
It lasts longer inside the engine.
  • bountyhunter
  • bountyhunter's Avatar
22 May 2015 13:08
#673178
Janosh wrote: I CANT FIGURE OUT HOW TO GET THE PRIMARY CHAIN OFF THE CRANKSHAFT. DO i HAVE TO SPLIT THE BOTTOM OF THE CRANK CASE?
Yes. Getting to that chain is basically tearing the engine all the way down to the last bolt. If you don't have a factory manual, you won't have a prayer.
  • Azzers
  • Azzers's Avatar
16 Aug 2022 03:35
#872323
Hi guys,
Primary chain slap is one thing, I've had that on my bike since I bought it, and its been fine.
Current Issue is I have had a starting issue on the bike, which was diagnosed as a worn starter clutch. That is, the starter isn't able to turn the engine over enough via the clutch as it 'slips'. I bought a replacement kit years ago that replaced the rollers and the pins etc. on the starter clutch and things went great.
Now all of a sudden I am at square one, same deal. What else could cause this issue? Could it be the primary chain is so worn/stretched that it slips on the crankshaft or secondary shaft gears? I have barely put 1000km on the bike since replacement of the starter clutch pins rollers etc. a few years ago.
'81 KZ750-E1 Cafe Racer Project - Complete
'79 CB750 K Restoration Project - sold
'82 GL1100 Bobber project - WIP
2014 BMW GS 1200 LC
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
16 Aug 2022 04:55
#872325
It´s the worn out surface of the starter clutch gear where the rollers can´t get any grip!
The following user(s) said Thank You: Azzers
  • Warren3200gt
  • Warren3200gt's Avatar
16 Aug 2022 05:09 - 16 Aug 2022 05:13
#872327
I've not read back through the thread but if you only used a repair kit and not replaced the whole unit then you were lucky it lasted 1000 miles.  You need to replace the whole starter clutch and possibly the starter gear to get good results.
A worn starter gear will chew through a new starter clutch unit in fairly short time.
Last edit: 16 Aug 2022 05:13 by Warren3200gt.
  • Azzers
  • Azzers's Avatar
16 Aug 2022 06:41
#872333
ok, do you think just the starter gear replacement will do the trick or that I should replace the housing again too.
That is that the damage is now done to the housing aswell?
Thanks so much for the quick replies guys!
2014 BMW GS 1200 LC
