shaft to chain conversion
  • matlock
  • matlock's Avatar Topic Author
20 May 2015 18:10
#672922
Ok I have an 82 kz750N and a 78 kz650... I want to make the 750 a chain driven motor... will the parts from the 650 fit in the 750?????
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: shaft to chain conversion
21 May 2015 06:41
#672968
couldn't you use the top end of the 750 on the 650 lower end??????????
21 May 2015 07:14 - 21 May 2015 07:16
#672972
531blackbanshee wrote: couldn't you use the top end of the 750 on the 650 lower end??????????
I believe the '78 KZ650 uses a regular link type cam chain while the KZ750-N uses a hyvo cam chain. Given that, there would be a compatibility problem between the cams and cam chain guides on the KZ750-N top end and the crankshaft in the KZ650 bottom end. Ed
Last edit: 21 May 2015 07:16 by 650ed.
  • martin_csr
  • martin_csr's Avatar
21 May 2015 07:32 - 21 May 2015 07:34
#672978
The output shaft on the chain drive models is different from the shaft-drive models, so you'd probably have to swap transmissions. I guess it can be done. ???
Last edit: 21 May 2015 07:34 by martin_csr.
