I did something stupid...kz750h3
  • dom2570
  • dom2570's Avatar Topic Author
Re: Re:I did something stupid...kz750h3
20 May 2015 08:08
#672866
home.comcast.net/~loudgpz/GPZweb/Ignitio.../PickupAndRotor.html
I screwed with the magnets and have spark again, but very weak. I am assuming they are not on right yet.
Whip it like a mule!
  • loudhvx
  • loudhvx's Avatar
20 May 2015 08:53
#672872
I assume you noticed the image of which type of screws go where. Don't mix up the brass screws with the steel screws.
  • dom2570
Re: Re:Re:I did something stupid...kz750h3
20 May 2015 10:23
#672881
loudhvx wrote: I assume you noticed the image of which type of screws go where. Don't mix up the brass screws with the steel screws.
I made sure of that. I didn't even notice that those back plates were magnets that actually served a purpose. I thought they were just spacers :pinch: I'm learning all sorts of fun stuff lately.
  • dom2570
20 May 2015 15:26
#672908
So this morning I removed the timing advancer got it cleaned really well with sea foam. I reinstalled everything and was getting good spark but backfiring from the carbs. Double checked everything and figured out I had switched the plug wires around. After that she fired right up.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
20 May 2015 17:10
#672912
Hooray!
  • dom2570
21 May 2015 12:47
#673011
I was riding today and noticed the front end is out of wack.
Hopefully the bars are just bent from going down.
If not the bar, what is the best way to check or realign the triple tree, or check the forks?
