I did something stupid...kz750h3
- dom2570
11 May 2015 18:55 - 11 May 2015 20:11
I was cleaning the timing advancer while it was still on the bike. I stupidly cranked the engine a few times the wrong direction...Now my bike won't start. How do I go about fixing this problem.
1982 kz750h3 ltd inline 4
I think it is an electrical issue. I was worried that turning it over backwards would cause the cams to jump teeth or something.
Time to get the wiring diagram and play what the hell is missing...
Whip it like a mule!
Last edit: 11 May 2015 20:11 by dom2570.
- KZPETE33
- 76 900 Constant thorn in my side....love it.
Re: I did something stupid...kz750h3
11 May 2015 19:24
Probably a 1982 LTD twin.
- RonKZ650
11 May 2015 19:26
It shouldn't hurt anything to turn the engine backwards. Of course shouldn't do it, but not likely to hurt. More likely an assembly mistake. On some bikes it's possible to put the ignition pickup, or whatever it's called, the part that is on the shaft that needs lubrication periodically that triggers the ignition as the crankshaft turns. On some bikes and systems it's possible to put this back on the crankshaft 180 degrees out of time.
- loudhvx
12 May 2015 07:22
As Ron mentioned... did you remove the rotor from the advancer? Then it's possible you put it on backwards.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
12 May 2015 07:57 - 12 May 2015 08:21
I'm assuming you cranked the engine by hand using a wrench? If so, what size?
You're supposed to turn the crankshaft clockwise using a 17mm wrench on the big crankshaft "nut".
I think there's a warning in the manual that if you turn the crankshaft by using the smaller inner
timing advancer bolt (14mm wrench), timing advancer damage might occur.
Also, the advancer bolt torque is 18-ft/lbs. When lubricating the advancer, separate the rotor from the body & fill the groove with grease.
Last edit: 12 May 2015 08:21 by martin_csr.
- dom2570
Re: Re:I did something stupid...kz750h3
12 May 2015 09:23
I never removed the advancer, I used a 17mm.
12 May 2015 10:45 - 13 May 2015 04:51
So, how did you clean it. I would remove, check & lubricate it properly. The thing is kinda important.
Last edit: 13 May 2015 04:51 by martin_csr.
12 May 2015 14:04
Points? Maybe they're all catywampas. Or dirty.
- KZPETE33
- dom2570
14 May 2015 21:18
I actually have been having issues with it cranking. I'm currently going through the wiring, hopefully I will find the problem soon.
- dom2570
18 May 2015 21:25
I have a new battery, plugs, and cables on the bike, but am getting no spark...what to do?
