V&H Baffle modification
  • jeff80kz1000e2
  • jeff80kz1000e2's Avatar Topic Author
08 May 2015 16:00
#671167
Hi all, I have a vance hines megaphone and its too loud with out the baffle (even with a helmet ), & too quiet with the baffle. Anyone ever drill out the baffle or modify it to make it louder? I have a few ideas in mind, but I want to save myself a headache if anyone has done it alteady. I just worry a bit, that if I drill too much or remove the deflector plate at the end of the baffle behind the final exit holes I might create a whistle possibly. Thanks in advance. Bike is an 80 kz1000 st
  • vernons
  • vernons's Avatar
Re: V&H Baffle modification
08 May 2015 16:13
#671168
I cut the back half of baffle off and it sounded quite nice... not too loud....
The following user(s) said Thank You: jeff80kz1000e2
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Re:V&H Baffle modification
08 May 2015 16:19
#671170
I left the baffle in my V&H but took out the packing. Ended up with a volume between fully baffled and completely uncorked.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • KZB2 650
  • KZB2 650's Avatar
08 May 2015 16:33
#671174
I've always ran the baffle with not packing ...... removed the backing plate years ago and it sounds real nice and defently a little louder that way ...... I recently bought a competition baffle and its a little quieter than the reg baffle without the plate. (No packing on it either).
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 May 2015 16:46
#671175
Try taking out the packing first. Here are the two. Stock and drag. I have the competition in it now. Turns heads every time and makes ponies with the packing still in.
Attachment Baffles001.jpg not found
Attachment Baffles002.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 May 2015 16:48
#671176
Sorry, I didn't reset the date on my camera.
  • jeff80kz1000e2
09 May 2015 18:59
#671290
StreetfighterKz wrote: I left the baffle in my V&H but took out the packing. Ended up with a volume between fully baffled and completely uncorked.
Later, Doug
Thanks, I didn't even realize at first that the baffles came with packing. I bought it used and the packing was already removed. I still think its too quiet with the packing removed.
  • jeff80kz1000e2
09 May 2015 19:02
#671292
KZB2 650 wrote: I've always ran the baffle with not packing ...... removed the backing plate years ago and it sounds real nice and defently a little louder that way ...... I recently bought a competition baffle and its a little quieter than the reg baffle without the plate. (No packing on it either).
Than ks. That info helps alot. Now I know that I can remove the backing plate and not waste money on the competition baffle if in fact the regular baffle with the backing plate removed brings up the noise a bit!
  • jeff80kz1000e2
09 May 2015 19:08
#671293
swest wrote: Sorry, I didn't reset the date on my camera.
No prob. Thanks for the pics. All the replies have pointed me in the right direction and now I can make a decision based on what info you all have given me. So I forgot to mention and didn't realize my used one actually had packing in it at one point. ( It wasn't there when I purchased it ). Which is just fine with me because the packing is out and it's too quiet for my liking. I'm gonna remove that backing plate at the exit behind the holes at the end of the baffle and see how I like that.
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 May 2015 19:24
#671295
I put on the Drag baffle and it was much too loud. Tried the stock one and it was like I put a cork in it's ass. The competition one is the best. Pulls clean through the red line.
  • jeff80kz1000e2
09 May 2015 19:34
#671297
swest wrote: I put on the Drag baffle and it was much too loud. Tried the stock one and it was like I put a cork in it's ass. The competition one is the best. Pulls clean through the red line.
Right on, appreciate the info. I think I will try a mod or two on this baffle that I have now. Now at least I know I have the option of the drag or competition baffles if all else fails. I suppose it depends on each of our individual thresholds on the decibels coming out of the pipe. For me, I just need it to be slightly quieter than the wide open pipe. I wear a helmet no matter what which allows me to tolerate more sound BUT it's AMAZING how gosh darn loud that straight pipe is even with a helmet on!! :silly:
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 May 2015 21:08
#671311
The first plate in the baffle isn't just for making it quiet. It also supports the baffle from inside. They also have a effect on tuning. With the drag one, I lost top end. I'm running 33 MM Miks. The stock one required re-jetting for it to work. When I pulled it out when new, I tried the Competition and it worked better. The sound is also.
I'd keep that in mind when modifying it.
