Engine nosie after slide
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Engine nosie after slide
04 May 2015 15:09
#670687
Tell that to the guys that don't adjust their valves because it's too much work or it cost money. :angry: They should be on Mopeds. :whistle:
Oh, and the ones that refuse to buy a manual. :evil:
The following user(s) said Thank You: Sleepy202
  • Sleepy202
  • Sleepy202's Avatar Topic Author
  • It is Time.....
07 May 2015 10:46 - 07 May 2015 10:48
#670998
Sorry for the late reply ladies and gents. Life has a habit of getting in the way. Thank you for the heads up on the service manual. I had been using it to change my tires. And I'll try timing my valves when the time comes......... Anyhow I have that video of the nosie. I believe it's coming from the lower part of the engin. Any ideas? I'll post the video in a second.
1980 KZ 550 ltd
Last edit: 07 May 2015 10:48 by Sleepy202.
  • Sleepy202
  • It is Time.....
07 May 2015 11:08
#671002
Here is the video link.
1980 KZ 550 ltd
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 May 2015 11:23
#671005
The engine is stumbling. Check you valve adjustments, then sync the carbs.
  • Sleepy202
  • It is Time.....
07 May 2015 11:30
#671008
I guess that time is now then ha!
1980 KZ 550 ltd
  • missionkz
  • missionkz's Avatar
07 May 2015 11:33
#671009
Just a quick thought:
To see if it is a cylinder or...? Pull one plug wire off at a time and increase idle speed a bit to keep it running.
If the noise really drops way off with one wire off.... you might have an exhaust leak or a crack somewhere.... etc
If no difference... you'll have to dig deeper.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • Tyrell Corp
  • Tyrell Corp's Avatar
07 May 2015 11:34
#671010
Sounds like a cold 550 motor to me, they all sound like cement mixers filled with rocks if you try to idle them when stone cold.
Cold cast Ally pistons need to expand to fit the cast iron liners, the clutch basket will rattle as the rubber dampers inside have aged, maybe a bit of wear in your primary chain and camchain coupled with some valve clearances out...all the usual suspects.
As above, balancing the carbs and checking valve clearances will likely improve things.
Try that again when it is hot, put a rag over the exhaust and rev it up, it should whirr like an electric motor.
  • Sleepy202
  • It is Time.....
07 May 2015 12:26
#671019
Alright. I will adjust the valves and sync the carbs. If that doesn't fix it then i will start to pull plugs. Thanks for the suggestions guys. I will update with results.
1980 KZ 550 ltd
  • bountyhunter
  • bountyhunter's Avatar
07 May 2015 12:46
#671025
I think it MIGHT be the primary drive chain clacking which these sometimes do at idle. Check timing, advancer assembly, and valve clearance.
  • pete greek1
  • pete greek1's Avatar
07 May 2015 13:51
#671031
When you went down, did your pipes get damaged ?
