Any hot tips on getting motor out of frame?
  • apbling
  • apbling's Avatar Topic Author
27 Apr 2015 07:21
#669737
Hi All.
About to swap 550 motors between daily rider and parts bike. I did this a few years ago, but I had the top end off, so it was significantly lighter and less top heavy. My thought was to have my motorcycle jack with some plywood raised up next to the bike, same height as the lower frame member. Then I was going to take my floor jack with some scrap wood on it and lift the motor just enough to clear the frame and then have a friend help me "shimmy" it over to my motorcycle jack.
I don't have a cherry picker or overhead winch. About all I have is a timber across my trusses in the garage and a ratchet strap...
  • loudhvx
  • loudhvx's Avatar
Re: Any hot tips on getting motor out of frame?
27 Apr 2015 07:57
#669742
Having two people is main thing. The 550 motor is light, but it helps to take off as much as possible. I usually have the alternator and starter off, and of course the carbs and sprocket cover. Then It's easy to take out, even with one person, but installation will require two people to prevent a lot of scratching of the frame. Make sure the bike is stable. It's going to want to fall over. Obviously it comes out toward the right.
Don't grab the clutch rod!
I assume you have the coils and airbox off. I can't rememebr if the horn interferes (never had one).
  • apbling
27 Apr 2015 08:34
#669744
Yep, carbs, coils, horn all off. Airbox too. side panels. I'll need to take the shifter off and most likely the rear brake pedal.
I was going to leave the bike on the center stand - will this not work?
  • loudhvx
  • loudhvx's Avatar
27 Apr 2015 09:33
#669753
I usually have the bike on the center stand, plus a very wide, stable support for the front, underside of the frame rails. The engine is what anchors the bike when on the center stand. When you start messing with the engine, the weight shifts front to back and the center stand becomes a rocking point.
Also, tie something on the center stand to the frame so it can't fold upward. Sometimes if you start to lean forward the bike rolls and up goes the stand.
At the very least, lock the steering and chock the front wheel.
The following user(s) said Thank You: missionkz
  • apbling
27 Apr 2015 09:49
#669755
ok. yeah, having that stand fold up would be cause for epic cursing, and I live in a suburb with lots of little ears running around in the yards.
  • MDZ1rider
  • MDZ1rider's Avatar
27 Apr 2015 10:37
#669760
I used the Ancra style self cinching hauling tie-downs as an improvised bike lift for years. Put 4 eyebolts in your roof trusses or loop soft strap extensions around an open truss. Hook a tie-down to each corner of the bike with the tie-downs angled just slightly outward. Raise it by rocking the bike from side to side, cinching up each corner 2-3 inches at a time. It only takes a few minutes with no heavy lifting to have the bike hanging a foot off the ground. Total investment is probably $30 and It's always good to have a set of tie-downs for emergency hauling anyway.
With a "lift" now available, I would remove both wheels and put the frame on the ground for removing/installing the engine.
  • KZB2 650
  • KZB2 650's Avatar
27 Apr 2015 12:06 - 27 Apr 2015 12:10
#669770
I should know how to link a thread by now but I don't. Search "Easiest way to get a engine out" if you would please .... its about 4 months old and has some good tips with pics ...... I used Bluej58's method a couple years ago and it worked out really good and easier than I thought it would be.
Will be doing it again soon myself for a starter clutch problem and have it all ready except for removing the mounts.
Good call on locking the center stand too guys...... I remember blocking the front wheel but will do both this time.
Edit ..... should a read your question totally first ....sounds like you did it j ;) ust like we did.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 27 Apr 2015 12:10 by KZB2 650.
  • loudhvx
  • loudhvx's Avatar
27 Apr 2015 12:34
#669772
Yes, for the bigger motors there are a lot of good tricks. I think I saw Bluejay's trick. But the 550 motor is small enough that nothing really extreme needs to be done. I've gotten them in and out myself with not too much trouble, but a second person helps prevent frame scratching on the install. Laying the frame down might have headaches with oil or brake fluid.
  • RonKZ650
  • RonKZ650's Avatar
27 Apr 2015 20:50
#669823
You've got it figured I think. The way I always removed a KZ650 engine was to make a table next to the bike of plywood supported by cinder blocks in the approximate height the engine is in the frame, then jack the engine up to clear the frame, heft it over to the table. I always did it alone, but having two would make it a lot easier without a doubt if you can trust your helper to not drop his side. I never trusted anyone enough to let them help. There are lot of guys that can't lift 50Lbs I've found over the years. Do it yourself and no worry about others dropping your engine on concrete.
  • apbling
13 May 2015 06:14
#671907
Well, I got it out. It definitely took some maneuvering to get it out. I almost didn't think it was going to come out for a while with the jugs and head on. Now the fun part will be getting it back in. Sure hope that the 81 and 82 LTD motors are interchangeable.... ugh.
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 May 2015 07:30
#671920
I had the guy next door try to help me with just the bottom end. I don't speak German but you would think so by the way he was acting. He got it cocked sideways so bad it wouldn't budge. I sent him home and used my little floor jack jockey it around enough so it would fit the mounts. The next day I rode by him and he had that WTF look on his face. MORON. He's the only one of my neighbors Pluto wanted to bight. He moved away and I was glad to see him go. The kind of guy that would come over, ask stupid questions and for a beer, get mad when told it's too early and stomp away. What he didn't realize is, I have all kinds of tools that can be thrown with deadly accuracy. He almost found out. :evil:
