1977 kz1000
  • steve620
  • steve620's Avatar Topic Author
1977 kz1000
21 Apr 2015 16:57 - 21 Apr 2015 19:10
#669062
i have a 1977 Kawasaki kz1000 and I took the stock air filters off and put separate filters on including the oil breather filter!!! well upon riding again the performance is crappy and the oil breather filter is filling up with oil and spitting it out of the filter. why is it doing this???? and how do I fix it???
Last edit: 21 Apr 2015 19:10 by steve620.
Re: 1977 kz1000
21 Apr 2015 17:59
#669071
The performance is crappy because you have not yet become a carb expert - but you soon will if you plan to ride with pods. :laugh: :laugh: Ed
  • kaw-a-holic
  • kaw-a-holic's Avatar
Re: 1977 kz1000
21 Apr 2015 18:03 - 21 Apr 2015 18:04
#669072
That's for sure. I know pods look cool but if it is just for looks, it's not worth the trouble. If you can find an old Henry Abe "bread box" filter the work a lot better.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Last edit: 21 Apr 2015 18:04 by kaw-a-holic.
The following user(s) said Thank You: steve620
  • steve620
Re: 1977 kz1000
21 Apr 2015 18:37
#669077
I got fed up with it and put back all the original stuff
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 1977 kz1000
21 Apr 2015 20:22
#669090
steve620 wrote: I got fed up with it and put back all the original stuff
A wise decision. :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • jlat
  • jlat's Avatar
Re: 1977 kz1000
22 Apr 2015 16:29
#669189
hello people; I'm new. Every time the pod subject comes up the word is to go back to stock. This is probably true and rejetting will make pods work but what about the OP question about the breather filter filling up? Maybe there's too much oil in the engine and I know from bikes past the breather does puke some oil but I nothing about the KZ's and how much does puke,
IBBY
  • Garbosh
  • Garbosh's Avatar
Re: 1977 kz1000
22 Apr 2015 16:50
#669193
With what Ive seen with breather filters, even on cars. The filters are for air, and not for oil so once the oil saturates the filter paper/fabric....it ends up saturating it so bad that when there is pressure, it spurts a little out of the filter paper/fabric that is now soaked in oil.
82 KZ1000P
Café Racer/ Brat Project
-Clubman Bars
-End Mirrors
-Rear Shocks
  • Garbosh
  • Garbosh's Avatar
Re: 1977 kz1000
22 Apr 2015 17:02
#669194
The oily fumes are what build up in the filter.
82 KZ1000P
-Clubman Bars
-End Mirrors
-Rear Shocks
  • z1kzonly
  • z1kzonly's Avatar
Re: 1977 kz1000
22 Apr 2015 17:46
#669196
Garbosh wrote: The oily fumes are what build up in the filter.
Oily fumes are blow by! From worn pistons and rings. Do a leak down test and see how much pressure is leaking into the crank case.
So, if you want it fixed! $500 for a over bore wiseco set of forged pistons, $150 for the boring job, Do the head while your at it, $400, $100 for gaskets! Do you love your Kaw enough?? $$$
Try some heavy duty straight, non-detergent SAE 50 or 60 weight oil. As long as you are in warm conditions. That will fix the blow by some. Or STP or Bardahl or some saw dust. Yes guys did this years ago selling used cars!
Blow by is caused by worn pistons and rings! :( :(
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 1977 kz1000
22 Apr 2015 18:36
#669201
The crank case ventilator is just that. It allows the blow by and heat to escape the engine. The drum collects the oil and sends it back to the engine. On KZ's its in front of the filter so it doesn't clog it with oil. If there is too much blow by the engine won't run for SHT anyway.
  • Kapahulu
  • Kapahulu's Avatar
Re: 1977 kz1000
23 Apr 2015 00:49 - 23 Apr 2015 00:50
#669239
z1kzonly wrote: Oily fumes are blow by! From worn pistons and rings. Do a leak down test and see how much pressure is leaking into the crank case.
So, if you want it fixed! $500 for a over bore wiseco set of forged pistons, $150 for the boring job, Do the head while your at it, $400, $100 for gaskets! Do you love your Kaw enough?? $$$. Blow by is caused by worn pistons and rings! :( :(
Right!
For jetting, 20 pilots and 120 mains are a good baseline for VM carbs on a KZ with headers and pods.
2strokeworld.com
Last edit: 23 Apr 2015 00:50 by Kapahulu.
