Popping or spitting out of carbs
- ewolpert
21 Apr 2015 09:48
Hey guys. My 78 KZ650B is running, but has developed a new problem. When throttling up (or down) from about 1/6 throttle up (only under load or in gear) I get a popping, backfiring or "spitting" out of the carburetors. This was not happening and is new. Before you ask, I have pods but stock jets and I do not own an airbox. The valve clearance and timing have been checked and adjusted. I have no idea what the cause or solution to this particular problem is.
Eddie
78 KZ650 b2a
78 KZ650 b2a
Re: Popping or spitting out of carbs
21 Apr 2015 10:13
Lean or air leaks. When I do jetting, I tell the client or myself to run it for at least 100 miles. Sometimes it will lean out. That just means the engine is breaking in and wants more fuel.
21 Apr 2015 10:23
Running pods with stock jetting is a bad idea. The engine will run lean and hot - not a good thing. Either rejet or get a stock airbox & air filter. Ed
21 Apr 2015 11:01
What I've seen here is guys putting on pods, 4/1 exhaust all at the same time and wondering why the bike won't run for SHT. Go one size up (pilots and mains), see how that works with one item only, then add the exhaust or pods and start again.
- KzChop82
Re: Re:Popping or spitting out of carbs
21 Apr 2015 11:48
Steve has this bang on- just did this same thing great result.
I had to go up an extra pilot size for mine- buts that's probably unique to my setup.
I was having trouble with idling.
Also- make sure your carb boots are creating a really good seal and you retorque your head nuts after the heat cycle.
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
- KZB2 650
21 Apr 2015 12:19
17.5 pilots, nettle up a notch and 117.5 mains are about perfect for mine. Ran the same only with 112.5 mains before I went with the 700 kit and 750 cam.
Air screws out 1 and 3/4 a turn too ....... will get them closer this summer with the color tune hopefully. make sure you have good carb holders too, new ones were money well spent I feel.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
21 Apr 2015 15:35
Yup.
- Twilightoptics
10 May 2015 17:41
Is there an online source for jets? I've got 102.5 mains that need a bump and no one seems to have anything local. Tempting me to get out the drill index.
1977 KZ650-B1
- Hamaya
10 May 2015 19:26Twilightoptics wrote: Is there an online source for jets? I've got 102.5 mains that need a bump and no one seems to have anything local. Tempting me to get out the drill index.
Jets R Us
1983 KZ550-M1 LTD Shaft
11 May 2015 01:57ewolpert wrote: Hey guys. My 78 KZ650B is running, but has developed a new problem. When throttling up (or down) from about 1/6 throttle up (only under load or in gear) I get a popping, backfiring or "spitting" out of the carburetors. This was not happening and is new. Before you ask, I have pods but stock jets and I do not own an airbox. The valve clearance and timing have been checked and adjusted. I have no idea what the cause or solution to this particular problem is.
Would also double-check the intake valve clearances, as insufficient clearance can result in backfiring through the carb.
And assure proper ignition timing and functioning of the advancer unit.
Good fortune!
