KZ900 Valve Clearance
- BIGKEVIN
14 Apr 2015 17:55
Can someone tell me what the correct valve clearance is for a 1976 KZ900. I have heard that it is between .002 and .006. I checked the clearance on mine today and they are the following:
#1 intake - .003 fits
#1 exhaust - .066 fits
#2 intake - .003 fits
#2 exhaust - .003 fits
#3 intake - .0015 fits
#3 exhaust - .0025 fits
#4 intake - .0025 fits
#4 exhaust - .006 fits.
Looks like the #1 exhaust is too loose. The #3 intake, #3 exhaust, and the #4 intake are too tight. Should I also see about putting a thicker shim in the #4 exhaust ? Thanks for any assistance.
1976 KZ900
2006 ZX6R
2006 ZX6R
Re: KZ900 Valve Clearance
14 Apr 2015 19:07
They should be between .002 -.004. If too tight you run the risk of burning a valve.
- missionkz
14 Apr 2015 19:48RIGHT! For the most part, better a little loose then too tight!!swest wrote: They should be between .002 -.004. If too tight you run the risk of burning a valve.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
14 Apr 2015 20:01
.066? What's the compression like on that cylinder?
- missionkz
14 Apr 2015 20:31I'm guessing that was just a sausage finger typo... probably .006"swest wrote: .066? What's the compression like on that cylinder?
Bruce
1977 KZ1000A1
1977 KZ1000A1
14 Apr 2015 20:49
Or a bent valve. Do they make feeler gauges that big?
- bluej58
15 Apr 2015 04:15 - 15 Apr 2015 04:18swest wrote: Or a bent valve. Do they make feeler gauges that big?
Been there done that :pinch: you can tell right away by sticking a small flash light in the exhaust port and looking in the spark plug hole for light.
note; check it with the lobe facing away from the bucket
JD
78 KZ1000 A2A
Last edit: 15 Apr 2015 04:18 by bluej58.
15 Apr 2015 06:28
You can double up on the feeler gauges. If in fact it is that big, bent valve. :ohmy:
