can chain sprockets
  • lux944
  • lux944's Avatar Topic Author
can chain sprockets
10 Apr 2015 22:42
#667471
:( hi can any one please tell me I have kz650 1979 engine number kz650be093597 im doing a top end rebuild started to put back together but noticed in the manual it says about the black rubber dampers that go on the cam chain wheels that sit in side the casings you have to glue them in but there were none there when I took it apart it says only on some models these were used bit stuck don't want to put back together a mess it up thanks
1979 kz650 frame number KZ650B 047050 ENG NUMBER KZ650BE093597
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: can chain sprockets
11 Apr 2015 05:36 - 11 Apr 2015 05:38
#667477
Those dampers are for noise reduction. You don't need them. If you're talking about the ones that hold the wheels in place you do.
Last edit: 11 Apr 2015 05:38 by SWest.
The following user(s) said Thank You: lux944
  • KZB2 650
  • KZB2 650's Avatar
11 Apr 2015 05:56
#667482
On the 4 small dampers that hold the wheels in place make sure you didn't drop em in the bottom end ..... I removed the oil pan to clean it all out anyway and found the 2 front ones I dropped. My 78 model had the rubber already glued to the cam sprockets and looked to be in good shape still.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • martin_csr
  • martin_csr's Avatar
11 Apr 2015 06:18
#667483
It helps to list the exact 650 model in your signature --- B, C or D if it's a 79.
You can check your frame & engine numbers at the following site.
jarlef z650
11 Apr 2015 06:34
#667485
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And the signature may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do.
Here's how:
Good Fortune! :)
11 Apr 2015 06:46 - 11 Apr 2015 07:42
#667487
The early 1977 KZ650 engines used cam chain sprocket cam chain guide roller shafts that were round from end to end (see first image below). If yours are like that someone replaced the original shafts with the non-damper type.
Your 1979 KZ650 engine should have cam chain sprocket shafts that have cutouts on the ends for the rubber dampers (see second image below). If the shafts on your engine have those cutouts you must use the rubber dampers (6 & 7 in 2nd diagram); if the dampers are missing you should be able to find replacements – ask here if you can’t find them. Ed
Attachment 00003a2-3.jpg not found
Attachment 00003a-10.jpg not found
Last edit: 11 Apr 2015 07:42 by 650ed.
