Backfire/Spitting out of carbs
- KzChop82
09 Apr 2015 17:48
What can cause spitting out of the carbs?
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
Re: Backfire/Spitting out of carbs
09 Apr 2015 19:02
Here are two possibilities.
Insufficient valve clearance, especially the intake valve.
Incorrect ignition timing, or sticking advancer.
- baldy110
10 Apr 2015 08:01
It can also be caused by the carbs jetted lean.
10 Apr 2015 08:17
My money would be on lean. Is it any better with the choke? Timing could be one tooth off being you just put it back together. I (assume) you got the valves to spec? With those pipes, it would be lean anyway, new valves and higher compression would change things.
