PLEASE READ-- NEED HELP!!
  • KzChop82
  • KzChop82's Avatar Topic Author
04 Apr 2015 10:57
#666506
I was putting the cam chain tensioner back on this morning and the damn pin on the left side was poking out- and I didn't see it while I was tightening the bolts.
A piece of the aluminum block chipped off.
Attachment ImageUploadedByTapatalk1428169401.482340.jpg not found
Attachment ImageUploadedByTapatalk1428169421.099956.jpg not found
Attachment ImageUploadedByTapatalk1428169441.017916.jpg not found
Attachment ImageUploadedByTapatalk1428169460.990518.jpg not found
Attachment ImageUploadedByTapatalk1428169492.839198.jpg not found
Attachment ImageUploadedByTapatalk1428169513.141144.jpg not found
Questions:
1. Pretty sure the tensioner is now unusable, correct?
1a. Buy a used stock tensioner, or go APE manual?
2. What's the best method of patching the missing aluminum? Jb weld? Silicone?
3. Is this area a "high pressure" area?
Please help- I'm at a loss here.
I was literally about 10 minutes away from firing the bike up!!!
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: PLEASE READ-- NEED HELP!!
04 Apr 2015 11:06
#666507
Could try some JBWeld to fix it. Biggest issue you're going to have is oil leaking from there. But if you can do a good job with the JBWeld and get the gasket surface flat, then a new gasket sprayed with copper spray on both sides may work. Structurally it should not be an issue. And aside from any possible links the tensioner should function normally. Be aware, the Clymer manual has the wrong torque listed. For the Z 1's and KZ900. It is correct in the table at the back of the engine chapter, but not in the body of the instructions. I just about stripped one of my tensionor mounting bolts thanks to the Clymer.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • KzChop82
Re: Re:PLEASE READ-- NEED HELP!!
04 Apr 2015 11:48
#666508
The clymer says 20 ft/lb- is that the right amount?
Clinton, NJ
  • spdygon
  • spdygon's Avatar
04 Apr 2015 11:53
#666510
the torque specs do not sound right .....all small bolts normally are in Inch/Pound.
Clymer books are not all correct...i would get a Kawasaki Manuel.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • KzChop82
04 Apr 2015 11:55
#666511
I do have one- haven't checked it yet. It's a PDF on my laptop.
Is there supposed to be a gasket between the block and the cam tensioner? I thought it was just an o ring?
Clinton, NJ
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Apr 2015 12:01
#666513
Get a manual one. I never liked the automatics. JB weld will work. It might seep but no high pressure there.
BUMMER. :(
  • spdygon
  • spdygon's Avatar
04 Apr 2015 12:08 - 04 Apr 2015 12:09
#666514
# 8 bolts are torque at between 11.5 to 16 Corse Tread
10.5 to 13.5 Fine Tread
Both at Inch / lbs
1974 Z1 900 project
Last edit: 04 Apr 2015 12:09 by spdygon.
  • KzChop82
04 Apr 2015 13:13
#666518
Attachment ImageUploadedByTapatalk1428177967.348305.jpg not found
I think I'm going to use this.
Clinton, NJ
  • KzChop82
04 Apr 2015 13:22
#666520
swest wrote: Get a manual one. I never liked the automatics. JB weld will work. It might seep but no high pressure there.
BUMMER. :(
Tell me about it...
I was about ten minutes from starting it up for the first time since the top end job!!
There isn't a gasket between the tensioner and the block, is there?
I don't recall one, the gasket kit didn't come with one- it just came with the o-ring...
Clinton, NJ
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Apr 2015 14:53
#666529
My machine has always had a manual one. I ran the stock one until this build. The stock one had a limited range. 30 years ago I had the bright idea of using a sprocket roller in place of the rubber one that would wear away. That and the fact I was using a Honda 450 plunger because it was longer, I broke a cam chain. I'm saying this because there are limits to what was designed. I was trying to use worn out parts longer. Bad idea.
You might be able to fix what you have and use it for a while. Find the manual one for that machine. If it came with a O ring, I suspect it fitted on the adjuster where it slid into the block. Does it have a groove? Pic?
You are so close now, don't cheap out or take unnecessary chances.
  • LarryC
  • LarryC's Avatar
04 Apr 2015 14:58 - 04 Apr 2015 15:04
#666533
Gut the tensioner.
Spray off the area with brake clean to remove oil traces..DO NOT SUBSTITUTE CARB CLEANER.
Apply tape to the indicated areas in the pics. Also on the tensioner body where the epoxy may get on it. Goal is to keep epoxy off the tensioner so it doesn't chip away when you remove the tensioner again...
Seeing as how it angles down a bit, probably put some tape over the epoxy plugged hole to keep it from running out.
If you mix the JB and give it a little time to form into a tighter mix before you apply it, you'll be better off. It's pretty runny at first. Heat also helps the cure and speeds the cure time. Hair dryer would work..
Install gutted tensioner and torque bolts to 8 ft/lbs [plenty of torque..no need for more]
Apply small amount of epoxy and let it set overnight.
Tomorrow remove the tensioner, remove the tape...assemble the tensioner [not the side plunger] and install. Torque to 8 ft/lbs. Make sure your timing marks are correct for the cams...turn motor over two revolutions and align timing marks & verify correct cam timing.... THEN bolt the valve cover on...THEN install the side plunger, spring, aluminum washer and cap on the tensioner...
Larry C.
Last edit: 04 Apr 2015 15:04 by LarryC.
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
04 Apr 2015 14:59
#666534
Yes, look it up on z1enterprises. But you can make one.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
