bent valves
- jlat
bent valves
02 Apr 2015 17:02
hello people; I'm new. To anyone who has a 1000 engine that has bent there valves. How many of the valves were bent and which ones?
I just received my valve removal tool and I hope to get to it soon. Any tips on removing the valves?
IBBY
IBBY
- Jcochran
Re: bent valves
05 Apr 2015 16:52
My experience with valve removal, isn't that great with motorcycles, but after a number of years building racing engines, you have two options. Depending on the degree of distortion from straight, you can either 1) simply heat and bend the valve as straight as possible to avoid damaging the guide that holds them in while making sure to not heat the head or valve guide, or 2) grind it off flush where it is bent (also making sure to not damage the guide) and remove it in two pieces, which is the most likely to keep you from damaging the valve guide. Be sure to check and make sure the valve guide isn't scratched either. Hopefully by bending the valve, it didn't knock a dent in the top of the piston, crack the head, or damage the guide, because if it did, the parts that are damaged will need to be replaced entirely and you may not be able to salvage them. Best of luck with the process!
1982 Kawasaki KZ250 CSR
- jlat
Re: bent valves
05 Apr 2015 18:00
hello; Thanks for the reply. I think I might of bent them while turning the engine over buy hand while the timing was wrong. The valves came out easy so we'll see. All of the intakes have a small circular mark in them all in the aprox. same place. As a member had noted that the valves were hitting each other rather than hitting the pistons as I originally thought.
IBBY
IBBY
Re: bent valves
05 Apr 2015 19:20
Do you have a manual?
- jlat
Re: bent valves
06 Apr 2015 17:07 - 06 Apr 2015 17:09
hello people; I took the valves to work today and there bent. Mostly around .050 and some oscillate. I didn't measure them all but there all junk.
I have a manual and it confused me with the timing as I said in another post. My cam has both lines and that small arrow that I didn't see. I went to the back of the manual to a suplement and it showed to time to the lines and I did and bent the valves.
IBBY
IBBY
Last edit: 06 Apr 2015 17:09 by jlat.
- spdygon
Re: bent valves
06 Apr 2015 18:09
If your Manuel is a Clymer...throw it in the trash.
Find your self a Kawasaki Manuel.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
Re: bent valves
06 Apr 2015 21:53
Arrow even with the head or just below it, if like mine, 28 teeth to the 28 arrow on intake sprocket. All done while the pointer is on T.
- chconger
Re: bent valves
07 Apr 2015 07:46jlat wrote: .....
IBBY
You have joined a large club of people. Those stupid lines on the exhaust cam have bent a lot of valves. The proper "V" mark on the sprocket needs a flashlight magnifying glass to see.
1977 KZ 1000-A
- jlat
Re: bent valves
13 Apr 2015 09:15
hello people; I'm new. I took my head to Harrys Machine Northborough Mass. this past Sat. I'll be on hold for now and I'll be back to tell the tail.
IBBY
IBBY
- jlat
Re: bent valves
14 Jun 2015 09:48
hello people; I finally got my head back. The only thing they had to buy but was the seals. I gave them a bunch of valves so they found usable ones. The labor was a killer. I have not been playing with my project and that's that. I need a head gasket and a couple more items.
One of the workers (Bobby) quit or left or whatever but that was the hold up. They did say to use a fiber head gasket. Tell me of your favorite?
IBBY
IBBY
