No Clutch Pressure
Re: No Clutch Pressure
01 Apr 2015 15:34
Click on add file, RT click documents, select, RT click pictures, select then the pic you want and select.
- KZQ
- Administrator
01 Apr 2015 16:07jmparish159 wrote: awesome ill give it all a try, including putting this new cable on then go from there. hopefully ill get positive results. and who is the webmaster? the uploading portion of this site still isn't working out. im sure once I upload pics someone will have a direct answer for me. its hard to describe I guess
Hi JM,
Please read through this thread.
www.kzrider.com/forum/8-about-the-site/5...posting-pics-is-easy
Regards
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- jmparish159
03 Apr 2015 12:35
okay I think I finally figured it out. once I took it all apart again, I noticed the clutch adjusting screw is in bad shape, so im guessing when I apply pressure it slips threads. im looking to order a new one. I use motorcycle superstore, but does anyone suggest a better website for kz parts?
03 Apr 2015 13:55
If it was mine and I thought the clutch adjusting screw was damaged I would buy the screw and the clutch release cam that it threads into in case those threads are also wonky. Partzilla is the place to buy them. See part numbers in diagram below. They have the adjusting screw for $2.10 - see
www.partzilla.com/search/?q=92009-1009&x=25&y=17
and the clutch release cam for $7.55 - see
www.partzilla.com/search/?q=13119-1003&x=19&y=20
Attachment 00003a-6.jpg not found
