Valve shims all out of stock!!
  • jordan
  • jordan's Avatar Topic Author
22 Mar 2015 18:51
#665291
I bought the kawasaki shim tool and was able to make an easy job of swapping shims. Luckily 4 of the shims were able to just be relocated to put a valve in spec. I still need three 2.30 shims and one 250. Z1enterprises is out of stock along with every other place I have looked! I found some online and after placing the order I recieved an email saying they will have them in a month. I need shims as soon as possible. Anybody have a vendor that they have had success getting shims from? Any 29mm o.d. Shim of the correct thickness should work correct? Also if anyone has these shims at home I would love to buy them from you
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Valve shims all out of stock!!
22 Mar 2015 19:33
#665297
Have you tried jetsrus?
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Mar 2015 19:35
#665298
Chaparral on line has shims and it shows if they are in stock or not.
  • jordan
22 Mar 2015 19:42 - 22 Mar 2015 19:42
#665300
swest wrote: Have you tried jetsrus?
Thanks Swest! Jetsrus is where I placed the order and was notified that they were out of stock
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Last edit: 22 Mar 2015 19:42 by jordan.
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Mar 2015 19:54
#665304
You can also try your small local shops. The one close to me will do a exchange + $5 to swap them.
  • jordan
22 Mar 2015 19:56
#665306
None at chapparal and Rocky Mountain atv is also out of stock :angry:
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • jordan
22 Mar 2015 19:57
#665307
swest wrote: You can also try your small local shops. The one close to me will do a exchange + $5 to swap them.
There's a yamaha dealer about 30 miles away, I will have to call them in the morning
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • bluezbike
  • bluezbike's Avatar
22 Mar 2015 20:35
#665310
Have a look at this post
www.kzrider.com/forum/2-engine/597404-kz...shim-exchange#664280
Perhaps someone can help you out......some yamahas also use 29mm. shims, I have one spare 250 shim I can trade with you (I have no 230's)
79 KZ 1000 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Mar 2015 21:17
#665313
You say you need 250. Would a 245 be within range and 225 instead of 230? I don't know if I have a 250 but the smaller ones I need for my machine. I knew I should have "tipped the valves. I have lots of the larger ones. They wouldn't help because I could only get .010 more clearance. I have one 210, 215 two 220's, 230,235 and 240's. Not much room left.
  • DFIGPZ
  • DFIGPZ's Avatar
26 Mar 2015 16:53
#665337
shoot me a email to b.flood@myactv.net I have over 300 shims i am sure i can get you going.
Barry
1984 750 Turbo
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
27 Mar 2015 03:05
#665381
Yes, shims are in very short supply. K&L Supply has been the major supplier for shims for decades. Mid last year they encountered some issues with the manufacturer and decided to find another manufacturer. They (and now everyone else) are still waiting for the first batch to come in. Part of the delay is their first batch is STILL stuck in a ship off the coast of California - a casualty of the dock strike that impacted 29 west coast ports.
Yes, Yamaha has (had) stock of many of the 29mm shim sizes. The XS1100's and other bikes use the very same shim. The Ford Taurus SHO engines (made by Yamaha) also use 29mm shims - although some f these are drilled with an oil hole in them.
K&L is expecting to see them in early April now. That means we should have them by mid-April.
  • jordan
27 Mar 2015 14:08
#665430
thanks Jeff for the reply, and sorry DFIGPZ I did not see your post until after i sourced some shims. I stopped at the local yami dealer and they had a few in the back collecting dust. Turns out they had exactly 3 of the 230's and just one 250. Exactly what I needed
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
