cam chain adjuster
- jlat
cam chain adjuster
22 Mar 2015 06:59
hello people; I'm new. KZ 1000 project. I see they sell a manually adjusting one. What do you think of that? It might be good for just working in that area. I've had by stock one of and on a bunch of times and every time I want to retract the adjuster I have to take it completely off. I need a new gasket and with the manual one you should never have to take it off.
IBBY
IBBY
Re: cam chain adjuster
22 Mar 2015 07:42
You have to be careful when using one.
- zukdave
22 Mar 2015 16:22 - 22 Mar 2015 16:23
Steve why do you say that ?
I run a APE tensioner and it's stupid simple
turn the bolt in by hand while turning the crank two rev.'s
then back it off 1/4 turn lock the jam nut you're done.
IMHO best $ 50.00 you could spent on your motor.
Why chance a 30+ year old part that CAN trash your motor
that has a known failure rate.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 22 Mar 2015 16:23 by zukdave.
- Tyrell Corp
22 Mar 2015 17:39
Kawasaki didn't make a lot of design faults, but I really think the 'automatic' tensioner wasn't their best idea.
IIRC The springs were uprated with a different part number on the GPz550 and maybe others.
22 Mar 2015 17:46
I say that because it can be adjusted too tight. If bought used then the owner can make a mistake costing a motor. If the cam chain rollers are worn out and there's no adjustment left, this thing can quiet it down until a broken cam chain is the result.
Guess how I know this.
