RC Engineerings cam followers.where are they now ?
Re: RC Engineerings cam followers.where are they now ?
16 Mar 2015 09:09
Did you try a magnet? Like to see them.
- DFIGPZ
16 Mar 2015 15:58
Sorry I bothered to reply :whistle:
1984 750 Turbo
16 Mar 2015 16:38
:huh:
- PaintWorkz
17 Mar 2015 09:42
These are the buckets I have that were in my TC when someone built it in the 80's. I think they might be the RC followers you are asking about . The shims are really difficult to pry out of the bucket. Since I am running stock cams with the turbo, I just put stock buckets back in it for easier shim swaps.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
17 Mar 2015 09:50
Cool.
17 Mar 2015 10:02Thanks RalphPaintWorkz wrote: These are the buckets I have that were in my TC when someone built it in the 80's. I think they might be the RC followers you are asking about . The shims are really difficult to pry out of the bucket. Since I am running stock cams with the turbo, I just put stock buckets back in it for easier shim swaps.
Hope to see you this weekend at the MT Clemens show. Give me a call and I will get you a pass
- zed1015
17 Mar 2015 10:42Yes! Those look like RC's. Thanks.PaintWorkz wrote: These are the buckets I have that were in my TC when someone built it in the 80's. I think they might be the RC followers you are asking about . The shims are really difficult to pry out of the bucket. Since I am running stock cams with the turbo, I just put stock buckets back in it for easier shim swaps.
Would be interested in the weight difference from the OEM buckets or whether the holes just compensate for them being heavier/thicker elsewhere in their manufacture.
Any signs of abnormal wear or fracturing between the holes.
- PaintWorkz
17 Mar 2015 11:16
They look thinner than a stocker to me. I do not have stocker to weigh but I will weigh a RC on a paint scale that measures in tenths of a gram.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
84 Gpz900 street
77 1135 KZ900 A5
- PaintWorkz
17 Mar 2015 12:15
The follower I photo'd weights 32.7 grams. There is a slight taper at the edge of the recess that allows the shim to rock a little to help when trying to pry it out, but the tolerance to the OD of the shim is a lot tighter than the stocker..... which would help the shim not get spit out.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
84 Gpz900 street
77 1135 KZ900 A5
- DOHC
- Those Doe-Hawks really go!
17 Mar 2015 14:11PaintWorkz wrote: The follower I photo'd weights 32.7 grams.
I get 35 grams on my mail scale, but that's probably not accurate enough.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- bluezbike
17 Mar 2015 14:39
I weighed 4 and came up with a range of 34.5 - 34.8 grams
79 KZ 1000 LTD
- zed1015
17 Mar 2015 17:42 - 17 Mar 2015 17:47
Only around a couple of grams lighter than stock then.
That's a bit disappointing considering that Ti retainers save around seven grams.
Every little helps though but the small weight loss may explain why no one makes them anymore with very little weight saving in return for all the extra machining although it shouldn't be forgotten that their primary function was to reduce the risk of shim spitting and the reduced weight was a bonus.
Last edit: 17 Mar 2015 17:47 by zed1015.
