Stator leak advice
- brich
Stator leak advice
04 Mar 2015 18:00
OK, I haven't posted on here in years. I also haven't ridden for years. I am fixing the bike back up. I had rebuilt it some years back with the help of many of you.
I put a new gasket and rubber grommet on the stator cover and it has leaked ever since. Small drip, but very annoying and occasionally makes it way to the pipe for a nice smoke-fest. Anyone else had this problem after putting new gaskets on? Any advice on this? Any gasket companies better than others? Any suggestions?
Also, any suggestions on where to get a rebuilt kit for Mikuni Smoothbores? I have 29's I think. Man it has been awhile. I just remember they were the expensive ones everyone wanted.
Thanks,
Brian
Thanks,
Brian
1975 Z1 900, 1075 wiesco kit, web cams, smooth bores, dyna ignition, denco pipe, lester mags, wicked bad rotors, custom gauge face plates .. not much stock left.
Re: Stator leak advice
04 Mar 2015 18:09
I bought a new grommet from Z1E. I filled behind it too. You have to splice the wires. The woven cover is where it leaks. I put some Crazy glue where the grommet would go to seal the woven part. Cleaned it first with carb spray. I know, I hate oil on my foot too. Lived with it for too long.
I get my gaskets from a seller on eBay. He's fast and the gaskets are good at a fair price.
The following user(s) said Thank You: brich
- brich
04 Mar 2015 18:14
Ahh .. the crazy glue. I wonder if I can hit off that fix without taking the cover back off!
Thanks for the advice swest.
I actually just ordered the new gasket and grommet from Z1.
05 Mar 2015 06:16
In order to replace the grommet you have to cut and splice the three yellow wires. I did it inside the cover. Next time I will do it on the out side past where they go into the clutch cover. Soldering the wires was a pain in the A. Not a lot of room to work. Oily wires and insulation. On the out side, it will be easier to clean and the splice/shrink tubing will be hidden by the cover. The crazy glue is just to keep oil from weeping through the woven part. Let it dry, then put the grommet on. I use high temp. copper silicon inside and out. Just wipe off the excess before it cures.
- DesertKZ
05 Mar 2015 12:24
I'll run a layer or two of heat-shrink over the wires where they pass through the grommet for added diameter on the wires. Never had a leak since
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- brich
05 Mar 2015 14:17
Yeah, I spliced mine outside last time I did it. So that part is good to go. Makes sense about how the woven part is wicking the oil through. I am going to use both of these suggestions. I will be a happy camper when that leak is gone. Thanks for the great advice fellas. Without it, chances are I would have silicone it again and ended up with the same result!
All the best!
All the best!
- spdygon
05 Mar 2015 16:57
i just finish replacing my grommet....and no woven shield come through to the outside.
woven stay inside the cover and only the three wires go through the grommet..once outside wires have a second plastic sleeve.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- bluej58
05 Mar 2015 17:24
I bought a new grommet 4 years ago and decided that I didn't want to cut the wires so I pulled the braided wires back into the cover and cleaned them with soap and water and after they dried out real good I used black permatex and worked it into the wires and pulled them back into the grommet then doped up the inside of the grommet with more permatex and it has held for around 25,000 miles so far.
78 KZ1000 A2A
