kz750 Twin Cylinder Head removal
  • mazeman02
  • mazeman02's Avatar Topic Author
Re: kz750 Twin Cylinder Head removal
16 Feb 2015 20:04
#661824
Ok So go with the versah kit then. Asked the seller just to be sure he is aware that the product described doesnt match the picture. And when he replies I will buy it.
  • mazeman02
16 Feb 2015 20:16
#661825
Gaskets ordered. Does anyone know where to get piston rings?
  • mazeman02
16 Feb 2015 20:29
#661826
No eBay APP ID and/or Cert ID defined in Kunena configurationagain people leaving out the year 79 or were these pistons different?
  • mazeman02
17 Feb 2015 01:11
#661840
hahaha just realized mine is an 80 woops
  • bountyhunter
  • bountyhunter's Avatar
17 Feb 2015 13:26
#661879
mazeman02 wrote: here is my build thread. So i am confused, the athena set is the one you bought or the one from ebay? which set did the gaskets fail on is what I mean. Because I would pay extra to get gaskets that wont .
www.kzrider.com/forum/11-projects/597190...-resurrection#661821
The Athena gaskets failed. I don't know if they were too old but they hardened and broke apart when the engine heat cycled.
  • bountyhunter
17 Feb 2015 13:29
#661880
mazeman02 wrote: Gaskets ordered. Does anyone know where to get piston rings?
These days I only see them on ebay.
  • mazeman02
20 Feb 2015 13:33
#662158
well the piston rings are not damaged so Im going to go with the used ones since I cant find replacements.
  • mazeman02
27 Feb 2015 09:19
#662878
Im not finding it in the manual for which gaskets get rvt and which ones dont
  • mazeman02
13 Mar 2015 10:51
#664330
im at the point of getting the pistons back in the jugs holy cow is it a pain in the A** haha any pointers on how to do it with the hose clapms or should i remove the pistons from the knuckle joint and go in from the top?
13 Mar 2015 11:14
#664333
Some folks reportedly find it easier to just use pop-sickle sticks or chop-sticks to aid getting the pistons into the cylinders, without using any other method of ring compressor.
Are the cylinders chamfered where the pistons enter the cylinders?
Good Fortune! :)
  • mazeman02
13 Mar 2015 11:39
#664337
yeah there is a 45 angle where the pistons go. So they need to be compressed. its nearly impossible since both pistons sit at tdc at the same height to do it by myself.
  • bountyhunter
13 Mar 2015 13:43 - 13 Mar 2015 13:47
#664347
mazeman02 wrote: yeah there is a 45 angle where the pistons go. So they need to be compressed. its nearly impossible since both pistons sit at tdc at the same height to do it by myself.
Biggest mistake I made was doing it by myself. I got them in OK the first time, but had to redo it all when the base gasket failed. Second time going in I broke a ring.
I ended up buying a set of ring compressors from JC whitney. I think it cost $60 for two, but it's cheaper than buying new rings which are not available any more.
One tip: Get a set of four very small vise grip pliers and wrap some tape on the jaws. Then I used them to clamp onto the long studs so they would support the cylinder as I was lowering it down. That way I could manipulate the clamps to get the rings compressed then let the cylinder down slowly.
Here's the ring compressor I used:
www.jcwhitney.com/performance-tool-pisto...6.jcwx?filterid=u0j1
Last edit: 13 Mar 2015 13:47 by bountyhunter.
