Cam motion Z1/KZ cam shaft specs
- turboking
11 Feb 2015 13:35
here is a list of cam motion cams for z1's/kz/gpz's for reference.
it's nice to be able to see specs when looking for cams.
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
Re: Cam motion Z1/KZ cam shaft specs
11 Feb 2015 18:17
What's the price of drop in cams.
- turboking
12 Feb 2015 05:33
:blink: I don't think cam motion makes any motorcycle cams for z1/kz's any longer .
......... :blink: I posted the cam specs off of an old list I had so some one looking at used cams could have an idea at what they are thinking of getting or comparing to other cam shaft brands..... :S :pinch:
1985 GS 1150E
1983 GS 1100E
1985 GS 1150E
1983 GS 1100E
- zukdave
12 Feb 2015 09:34
I think all KZ cam's will be hard welded and reground.
on your core's.
Webcam cam's for my GPz750 run about $450.00 a pair.
on your core's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Sayonara
- The faster the better
01 Feb 2022 20:46
Hello the chart is really useful, one question where does it refers to the base circle? is 110? were it says center to lobe.
I grew up riding and fixing all sort of small bike until I inherited A 1977 GS 750 when I was 16, that changed my life completely I love metric bike and I own a few fully working and have some projects.
- Injected
02 Feb 2022 08:58 - 02 Feb 2022 09:03Just for reference I have a Z9 in my drag bike, it has a 1.040" BC. Most lower lift cams have a bigger BC - 1.070" to 1.110". A lot of the higher lift cams (+.500") will have a BC of 1.000" and sometimes less.Hello the chart is really useful, one question where does it refers to the base circle? is 110? were it says center to lobe.
All I see on that chart is timing specs for a 110LC - This is to check a baseline setup and has nothing to do with the BC.
Here is a list of Cam Motion grinds for 900/1000/1100 that gives the Base Circle :
Z1 - .400 Lift, 1.110" BC - Duration 2xx'
Z2 - .385 Lift, 1.110" BC - Duration 258'
Z3 - .345 Lift, 1.090" BC - Duration 241' turbo cam
Z4 - .420 Lift, 1.110" BC - Duration 269'
Z5 - .429 Lift, 1.060" BC - Duration 252'
Z7 - .429 Lift, 1.060" BC - Duration 272'
Z8 - .455 Lift, 1.050" BC - Duration 271'
Z9 - .465 Lift, 1.040" BC - Duration 278'
Z10 - .485 Lift, 1.000" BC - Duration 272'
Z11 - .485 Lift, 1.000" BC - Duration 279'
Z12 - .485 Lift, 1.000" BC - Duration 260'
Z13 - .520 Lift,1.000" BC
Z14 - .507 Lift, 1.000" BC
Z16 - .490 Lift, 1.000" BC
Z17 - .485 Lift, 1.000" BC
Z18 - .485 Lift, 1.040" BC
Not sure where I grabbed this from but this is just for "reference" - All new or used cams must be measured to make sure they will work in your cylinder head.
1978 KZ650B2 modified project
Last edit: 02 Feb 2022 09:03 by Injected.
- Sayonara
02 Feb 2022 12:12
Thanks
