Trouble starting
- jsnabbs
- 1981 kawiKZ440
Trouble starting
03 Feb 2015 13:45
Hey guys, im back with a new trouble.
well the bike is back together, somehow finished, but not as finished as i thought
Heres a link to the build
www.kzrider.com/forum/11-projects/592417...first-build-finished
So today i thought i would fire it up, first problem, as i put petrol in, it came straight back out of the front of the petcot. So i drained it all out, and as luck had it, i had the new gasket for the petcot in my workshop.
So next try, petrol in again, all good, didnt leak. but somehow she wouldnt fire up. Was a couple of times just about there, it wanted to, but no cigar. i didnt want to try too long as i have a new shorai battery, and you're not ment to run them flat. so i left it at that.
I took a couple of pictures of the tubing from the tank to the carb, can someone confirm i have this right please
It all seems a bit strange as the guy who did the electrics said he got it running after a couple of cycles, he used a secondary tank, so no gas running from my tank to carb. now it seems strange that 1 week later i couldnt get it going.
this is the first start/ or second
start up after the complete rebuild, so im all ears for suggestions.
thanks a million in advance
Attachment IMG_1275.jpg not found
Attachment IMG_1276.jpg not found
Attachment IMG_1274.jpg not found
Attachment IMG_1277.jpg not found
TIME TO TRADE IN THE PEDALS FOR SOME POWER
- Tyrell Corp
Re: Trouble starting
03 Feb 2015 14:28
sounds like your carbs are dry, set fuel tap on 'prime' if it has't been run for a while.
From your pics, black tube is fuel tap outlet to fuel rail on the carb bank, green tube is vaccum from one intake rubber for the tap : this shold go to one of the intake manifold take offs. You may have three blanked off and one for the fuel tap.
03 Feb 2015 17:36
Open the drain screw. The float may be stuck, the diaphragm in the pet cock may be bad or no vacuum to it.
- jsnabbs
- 1981 kawiKZ440
03 Feb 2015 19:29
the diaphram is this sqaure rubber part in this link?
www.darkhorsemotorcycleparts.com/assets/images/18-2698-1.jpg
as it was leaking out the front i canged the cirlce part with the 4 holes, and the o-ring that goeas out outside of tap. there was all so a metal shim that came out from behind the tap, in between cirlce part with 4 holes. im so silly that now im home and i didnt think to check if gas is running from hose when tap is turned on
- jsnabbs
- 1981 kawiKZ440
04 Feb 2015 07:01
Well when i filled it the first time it was leaking from the front of the petcock, but all so flowing through the black hose. i guess i somehow cut fuel supply of when i change the 2 rubber gaskets in the front of the petcock. anyone know why there is all so a metal shim in the front of petcock?
04 Feb 2015 07:18
That's a spring to keep the lever against the rubber gasket. That's why the leak.
The following user(s) said Thank You: jsnabbs
- jsnabbs
- 1981 kawiKZ440
04 Feb 2015 11:43
from the photos can you guys please tell me if i have the plumbing of the gas tubes right, it was really a long time ago since i took it apart
04 Feb 2015 18:31 - 04 Feb 2015 18:45
Where there are two nipples on a vacuum operated petcock, the smaller nipple is for attaching the vacuum hose from the carb or carb-holder, and the larger nipple is for the fuel line that runs to the carb.
Last edit: 04 Feb 2015 18:45 by Patton.
04 Feb 2015 19:07
If needed, this link is to a down-loadable service manual.
www.kz400.com/WorkshopManFrameset-5.html
